FixYa.com
Hotpoint Aquarius WMA52 Front Load Washer
All Products > Hotpoint > Washing Machines
Problems with Hotpoint Aquarius WMA52 Front Load Washer?
Troubleshooting and Support
Solved Problems for Hotpoint Aquarius WMA52 Front Load Washer RSS Feed Post a New Problem
when the washer go s on rinse the prewash...
when the washer go s on rinse the prewash flashes and stops
1 Solution
Belt has come off - how do i put in back?
The machine made quite a loud banging noise then stopped spinning but continued with a whizzing noise, when the machine...
1 Solution
hotpoint 761 washing machine, leaving...
my machine is only 3 months old, I took the drawer out to clean it and noticed that above that it was completely black...
1 Solution
Hotpoint Ultima WMA61 loud knocking noise...
Hi could anyone help me, my washer is making a very loud knocking noise when it goes into the spin cycle it sounds like...
2 Solutions
Door will not lock
Hotpoint Aquarius WMA52 has got an intermittent fault. Program starts and then at random "door unlocked" light...
1 Solution
broken washing machine
my machine started making a loud noise as if stones were stuck in machine or something metal was grinding against...
1 Solution
help me
i have a hotpoint aquarius and the damm thing will not empty the water have tried to run a cycle but after a few mins it...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Hotpoint Aquarius WMA52 Front Load Washer RSS Feed Post a New Problem
Belt replacement
We cannot get the belt on , tried to loosen the motor , but is built into the plasticframe from the drum ?
Post a Solution
suspect bearings gone
wheering noise coming from drum on spin.How do you change the bearings
Post a Solution
Its actually a WMA54 ... can I change the...
... I mean can I physically replace it? Is it easy to do that? Does it cost a lot? Is it worth it ... or should I go...
Post a Solution
Hotpoint WM52 first Edition
It will wash my clothes just fine but when it comes to spinning them it wont. I have had the bushes done about a year...
Post a Solution
WMA52 DOOR GASKET
How difficult is it to change the door gasket
Post a Solution
noise coming from the drum
drum making noise when on spin been advised that it could be the bearings could you tell me were to locate them thank...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Washer TypeWasher
Load TypeFront Load
Weight Capacity13.22 lb.
Wash
Spin Speedsmax. 1100 rpm
Dimensions
Overall Depth22.84 in.
Overall Height33.46 in.
Overall Width (Display)23.43 in.
Warranty
Warranty1 Year Parts and Labor · 5 Year Parts
Hotpoint Contact Information
Main support number0870 442 7665
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
