20 Most Recent Audiovox CDM8910BM Questions & Answers
hello This may sound alittle to easy but hit the unlock button and then look to see if the phone is telling you how to unlock it. SOMETIMES YOU HAVE TO HIT THE * KEY AND THE UNLOCK KEY. If this doesn't work take it to your local carrier they may have a way to uplock your phone or tell you your code
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Audiovox... | Answered on Nov 05, 2010
Try this. Take the battery out. Wait 30 seconds. The phone memory should reset itself. Reinstall the battery. Turn on the phone before you plug it in. It should come on for just a couple of seconds. Then plug it in. See if that helps. If not, behind the battery there should be a reset button. Try resetting the phone there. Make sure you have all your phone book down on hard copy. You will loose all your information by resetting the phone that way. But it does reset it completely. Also make sure your phone has been updated. Either online or at your phone service by a tech. Good luck.
Audiovox... | Answered on Dec 31, 2009
Am si eu un nokia 2630.*** am scapat eu de "Pliculetul" care i-mi inchidea tel MENIU - MESAJE - STERGERE MESAJE - TOATE MESAJELE. DECI nu am reusit sa sterg dar apasand continu tasta OK am reusit sa apas in momentul in care a aparut pliculetul si a inceput sa stearga dar nu in totalitate ca sa inchis tel, am repetat procedeul si iar...,si iar... dar observam cu cat se sterg mai multe msg cu atat mai repede apare pliculetul , trebuia sa ma misc mai repede cu tastele telefonului pana am ajuns la ultimul si nu mai reuseam , am trimis cateva msg de pe un alt tel si sa marit putin timpul de aparitie al pliculetului ,am mai incercat o data si GATA Va doresc succes si multa rabdare. (driver777mary)
Audiovox... | Answered on Nov 30, 2009
go into menu
go to settings
go to security, you will need to enter your code, which is normally the last 4 digits of your cell number ph #
go to option 8 "reset phone" THE SCREEN CAN ONLY SHOW 7 OPTIONS,
so go to option 7 and press down and the screen with option 8 appears, and that is where reset phone is at.
Audiovox... | Answered on May 20, 2009
hold the off button on for approx 7 seconds and release. If you hit it again it will shut back off without appearing to come on at all.
go into the menu
go to settings
go up to go to next screen in others (the phone only shows the first 7 options, scroll past to options 8&9)
now while in "others" go to voice settings and choose "off" and then hit OK
hit the red button (off) And escape to the main screen, close your phone for 3 seconds and open it and its done.
hope this helps
try the last 4 numbers of your cell number
Audiovox... | Answered on Jun 02, 2008
Hi, if you hold down the * (star) key, the vibrating phone logo should dissapear from the screen and etiquette mode will be off. Hope this helps! Si :)
Audiovox... | Answered on Sep 27, 2007
get a new battery mate, before the fluid damages the phone. have a look on ebay or check out a cell phone store.
Audiovox... | Answered on Sep 11, 2007
You need to purchase a code from Zesium
Audiovox Cell... | Answered on Mar 18, 2019
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Audiovox Cell... | Answered on Nov 02, 2012
For this problem contact the mobile service provider,.....
Audiovox Cell... | Answered on Sep 25, 2011
Audiovox CDM8910BM Logo
16 questions posted
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Cell Phones
Most Popular Question
cannot reset phone
  • Cell Phones
