20 Most Recent Samsung SPH-a460 Questions & Answers
I recommend you a good website http://www.laptopbattery4.co.uk.Hope you can buy a laptop battery that you wanted.
Samsung SPH-a460 | Answered on May 14, 2012
If the vibration works the circuit is working OK. All what can be done is to reset the phone , remove battery and reset, check for any corrupt files on the memory card. Now open settings, tones and check the default settings. check tone set and tune selected. Now if there is no result the ringer might be open and faulty. You can check the continuity to confirm , if so replace.
Samsung SPH-a460 | Answered on Sep 27, 2011
hi justin,
you may wanna visit this link for reference:
http://www.samsungtelecom.com/PDF/A460.pdf
to change the ringer volume from the main menu:
1.press menu for menu options
2.press 8 for sounds
3.press 1 for ringer volume
4.press 1 fro calls
5.select off/vibrate/1-beep/level1-8/ring+vib,and press ok
Samsung SPH-a460 | Answered on Apr 14, 2011
*2767*3855#
Samsung SPH-a460 | Answered on Feb 01, 2011
you need to push the # key,and it will exit silent mode, please vistit my blues radio station
www.thextexasblues.com
Samsung SPH-a460 | Answered on Jan 28, 2011
To shut off the silent mode of your phone, you need to go to the main menu of the phone, go to settings, then you go to the phones profile and select the profile of your choice, take it away from the silent mode and back to your profile of choice.
That should do the job for you.
Samsung SPH-a460 | Answered on Jan 09, 2011
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Samsung SPH-a460 | Answered on Jan 04, 2011
just press and hold the # key
Samsung SPH-a460 | Answered on Nov 30, 2009
Haha I had the same problem hold down the button on the bottom right which is the pound key. and itll come out of silent mode.
Samsung SPH-a460 | Answered on Oct 20, 2009
humidity or water could have damaged the earpiece speaker phone. an electronic mechanic may be able to fix it.
Samsung SPH-a460 | Answered on Feb 23, 2009
Moto H300 should be "0000"
Samsung SPH-a460 | Answered on Feb 19, 2009
it is not wise to do that
Samsung SPH-a460 | Answered on Dec 01, 2008
it would not adviced you to changed your ESN number on the phon doing that could brick your phone.
Samsung SPH-a460 Logo
29 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SPH Samsung
  • SPH Samsung
Most Popular Question
need 6 digit service code samsung sph
  • Cell Phones
