20 Most Recent Samsung SPH-a660/VI660 Questions & Answers
The IMEI number is unique the each mobile/cell phone.The number is printed on the label under the battery.You can also get the IMEI number by entering this onyour phone *#06# It will then display your IMEI number andyou may also get a unique global serial number. Your IMEI number should be 15digits.
Samsung... | Answered on Jun 18, 2012
You may need a software update to your phone. You will need to call your cell provider and inform them of the problem. A software update will usually clear this up.
Samsung... | Answered on Sep 20, 2011
remove battery and reinsert it. or battery has gone too low and my need boosting before you reinsert it.
regards
Samsung... | Answered on Jan 23, 2011
Try looking for your model on houdinisoft.com on the help desk.
Samsung... | Answered on May 08, 2010
really since it was milk and not water, and should form up as as sort of buttery material inside the phone.......unlike water that carries minerals that aid in the transfer of electric current, milk has much less ability to do so and should be hardened within a day or so.......If you really want to be cautious, you need to disassemble the device completely and clean it with isopropal alcohol. Thats about all you can do and good luck...........your phone shouldn't get any worse that it is now and if you see intermittent glitches then you may need to clean it. Good Luck and pls rate this post!!!!!!!!1
Samsung... | Answered on Dec 30, 2009
There are two things involved in this issue. The problem is either from the phone network provider or from the phone itself. It is also possible that there is no reception in your area.
What you need to do in a situation like this is to be sure first if your phone network provider is not having any problem with service provided.
When you are convinced that the fault is not from your phone network provider, I will be left with no choice than to suspect your phone.
At this stage, I think the fault is from your phone network. You will have to visit a phone repair shop for it to get fixed.
Take care.
Samsung... | Answered on Dec 08, 2009
You should look at your plan to see if you have texting
Samsung... | Answered on Jun 30, 2009
Without knowing your capabilities as a tech it's impossible to say. Personally I think it's easy but I'm used to doing that type of work. If you do decide to do it yourself the hardest part is often actually getting the case apart. Some manufacturers are beginning to use screws which need weeird things like 3 bladed screwdrivers (like a Philips screwdriver with one blade missing and the other three off center) Then there's the units which need prying apart. You have to know excatly where to pry to diengage the plastic locks inside. If you break them you'll have to glue the unit back together :-) If you do get inside the screen could be anchored by double sided adhesive tape and this can make you think it's anchored by screws you can't see. Some units are extremely easy to do a transplant on whilst others seem to be designed to stop anyone from doing so. If you're willing to lose the phone altogether, give it a go but if you feel confident then good luck. BMW
Samsung... | Answered on Apr 02, 2009
You have to take it to the service center, that is not battery issue else it would have turned on when connected directly to the wall.
This seem issue with the mother board, and there is a 50% chance of retrieving the data stored. it is will cost 80% of the cost of the phone to change the motherboard.
Let me know if you need more help...Kevin
Samsung... | Answered on Mar 27, 2009
I have the same problem. You have to use the area code, the full 10 digit number. Even the phone numbers stored in your memory need to include the area code for the text to send.
Samsung... | Answered on Dec 26, 2008
get new phone
Samsung... | Answered on Dec 18, 2008
Go buy a new phone ****
Samsung... | Answered on Oct 28, 2008
Samsung SPH-a660/VI660 Logo
47 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SPH Samsung
  • SPH Samsung
Most Popular Question
cell plone lg gr500 fell in milk
  • Cell Phones
