20 Most Recent Nokia 6100 Questions & Answers
IMEI: 353396/00/622606/7
MODEL: 6100
DEAR SIR SWICH ON SECURITY CODE
Nokia 6100 | Answered on Jun 04, 2019
6100 Manual
Nokia Cell Phones | Uploaded on Oct 14, 2013
i need GPRS HELP
Nokia 6100 | Answered on Oct 10, 2013
You can reset your mobile using master reset code. Get the code from the site Unlocking4free.com ,and reset your Nokia 6100 from your protection code easily....
Nokia 6100 | Answered on Jun 29, 2013
Yes u can i do it all the time have to be able to notice the two
Nokia 6100 | Answered on Feb 06, 2013
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Nokia 6100 | Answered on Nov 03, 2012
firstly check that whethere ur phone provides gprs ,if yes than talk to ur network provider executive and tell him to activate gprs connection
Nokia 6100 | Answered on Oct 12, 2012
it should explain everything in the manual you should have got with the camera. if you didn't get the camera manual then the best place to look would be the manufacturer's website.
hope this helps
Nokia 6100 | Answered on Oct 06, 2012
Hi
Instead of flashing you can unlock your mobile by using codes.you Can get free codes from http://www.unlock-free.com/nokia/nokia-6100.html.Try this dude.
Nokia 6100 | Answered on May 02, 2012
you can contact the service provider........
Nokia 6100 | Answered on Nov 06, 2011
You need to unlock.
Hi You can unlock your mobile for free by getting codes from http://www.unlock-free.com/nokia/nokia-6100.html.Check this dude.
Nokia 6100 | Answered on May 24, 2011
Hi there!
If you're encountering this kind of problem on your phone then all you have to do is powercycle your phone.You can do that by removing the battery while the phone is on.After 15 seconds kindly reinsert the battery and turn the phone on again.If you still have the same error message then kindly go to a different location because it might be that the phone is not getting a good reception.And if you still have the same problem then kindly contact your service provider because its a probable issue with the network,not with the phone.
Thanks!
Nokia 6100 | Answered on Apr 17, 2011
signal problem... not worth repairing
Nokia 6100 | Answered on Apr 07, 2011
This tutorial will show you how to upgrade your iPhone 4 to iOS 4.3.1 without upgrading its baseband using TinyUmbrella for Windows.
Currently there is an issue with older basebands such as 1.59.00 and FW 4.3.1. Until ultrasn0w is updated, you will only see one bar under signal strength.
Please Note: This ONLY Works with the iPhone 4!
Step One
Download TinyUmbrella from here Also make sure to download the iPhone 4 iOS 4.3.1 which you can find here.
Step Two
Double click the downloaded TinyUmbrella.exe file.
If you get a Windows Firewall notification, check both boxes and click Allow Access.
Step Three
Make sure the device is connected, and Umbrella has detected the type of device and its firmware.
**If you haven't already saved your iOS 4.3.1 SHSH blobs then click Save SHSH. Make sure they successfully save before continuing.
Step Four
Hit Start TSS Server and make sure you receive no errors.
Once The TSS Server is "running" successfully, umbrella will kill iTunes. Leave TinyUmbrella Open. You can double check to see if the TSS server is running under the Log tab.
If you do receive an error, DO NOT continue. Your restore will not work if the TSS server cannot be started.
Step Five
Open iTunes by doubling clicking its icon.
Hold down the Shift key and click Restore
Select your iPhone 4.3.1 firmware file from the popup window that appears and click Open.
Click Restore to begin restoring your device.
Step Six
iTunes should give you error 1013. This is what we wanted, as it notes the baseband has not updated :) Click Ok and close iTunes.
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are working with a device OTHER than iPhone 4.
Step Seven
Place your iPhone into DFU mode by holding down both the Power and Home buttons for ten seconds, then release the Power button and continue holding the Home button for another 5 seconds. You can find help with DFU mode here.
Step Eight
Fix Recovery in TinyUmbrella is currently not working. Download this standalone .exe file to fix recovery on 4.3.1. Extract the file and double click on fixrecovery43.exe. A command prompt will open, and the program will go through the process. During this time, you will notice scrolling text on your iPhone 4.
Step Nine
Your iPhone will now be on 4.3.1 with the 1.59.00 baseband! (Which means you can now unlock using this tutorial)
**Thanks to semaphore for his work on this tool
Nokia 6100 Logo
113 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
contact service nokia 6100
  • Cell Phones
