FixYa.com
IBM G74 17 in.CRT Conventional Monitor
All Products > IBM > Monitors
Problems with IBM G74 17 in.CRT Conventional Monitor?
Troubleshooting and Support
Solved Problems for IBM G74 17 in.CRT Conventional Monitor RSS Feed Post a New Problem
Objects on screen out of window
I've had an IBM G74 monitor for 10 years. Until recently, it's been working fine. I'll try and explain the problem. ...
1 Solution
IBM G74 Monitor
My monitor is distorted. it seems to be wide at the top and bottom and curves in the middle. I cannot play some of my...
1 Solution
Manual for Sharp zq 290 h
I am trying to get a manual for my sharp zq 290 h pda organizer
1 Solution
Picture but no sound on Hyvision LCD...
I have a Hyvision LCD monitor MV190. There is no volume coming from the speakers. I hooked up the monitor to use as a...
Post a Solution
Flat Screen Monitor has No Power
I have a HPVS19D flat screen monitor. I have had this monitor for a little over a year. When I turned on my pc today,...
Post a Solution
Computer Monitor Compatibilty
I am thinking of buying an HP 24 inch monitor for my 4 year old Dell 8400 Dimension desktop system. Can I expect this...
1 Solution
hi lcd
hi, the screen of my monitor(computer) when i open a some game are shaking
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for IBM G74 17 in.CRT Conventional Monitor RSS Feed Post a New Problem
Control buttons not working
I have IBM monitor 2 years old. Suddenly my son pushed one of the control button & it struck. Afterwards no buttons...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size17"
Max. Resolution1280 x 1024
Dot Pitch.27 mm
Monitor TypeCRT
Viewable Picture Size15.9 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalUL · FCC Class B · CSA · DHHS · PTB · SEMKO · GOST-R · DEMKO · FIMKO · PCBC · SASO
Synchronization Range - Horizontal30 - 69 kHz
Synchronization Range - Vertical50 - 120 Hz
Dimensions
Depth17.1 in.
Height17.1 in.
Width16.8 in.
Weight40.8 lb.
Warranty
Warranty3 Years
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
