Eizo CG-19  19 in. Flat Panel LCD Monitor
Problems with Eizo CG-19 19 in. Flat Panel LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for Eizo's latest driver updates.
Troubleshooting and Support
Solved Problems for Eizo CG-19  19 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
Monitor trouble
I have a westinghouse monitor and we had a wind storm .My server went down for about 5 minutes and when it did my...
1 Solution
L222WT flatron 21.6 monitor is not working
When the monitor is turned on, the LG symbol/logo appears as if it will then go to the Windows Vista page. Instead,...
1 Solution
bzzzing noise coming from monitor
my monitor is making noises, like an electrical bzzz. Could it be a corrupt profile or is it hardware? other than that,...
1 Solution
dell monitor for dimension 2350
lately my monitor keeps blanking out... I was told that a patch could fix the problem.. I hooked another monitor to the...
1 Solution
.ct 2070 display not clear
Hi,  we have the lct 2070 akai monitor.  I have hooked it to the computer and its working but, the fonts are...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio450:1
Brightness280 cd/m
Dot Pitch.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time20 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · UL · FCC Class B · C-Tick · CSA · CB · TUV-GS · TUV-S · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · TCO-03 · TUV-ERGO · CCC
Digital Video Input StandardDual DVI-I
Synchronization Range - Horizontal30 - 82 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical170
Native (Recommended) Resolution1280 x 1024
Synchronization Range - Vertical49 - 86 Hz
Dimensions
Depth2.5 in.
Height13.4 in.
Width16.3 in.
Weight12.8 lb.
Warranty
Warranty5 Years
Eizo Contact Information
Main support number1-888-900-8383
Email supportsupport@eizo.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
jackboy Wiz
4 solutions
Ask Me
CompuGuy4 Wiz
2 solutions
Ask Me
modern Wiz
3 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
