20 Most Recent Panasonic NV-GS22 Mini DV Digital Camcorder Questions & Answers
-Have you try add new hardware...? If not then do so.
-Plug the device into then go to control panel >device and printers>file > add a device > then just follow trough the instruction.
You should be able to access to and install.
Good luck
Mai
Panasonic... | Answered on Jan 16, 2018
Put the card in
Panasonic... | Answered on Apr 23, 2012
Yo! I will have to direct you to a website where you can download anything for your computer. please follow the links below..
www.download.com
http://www.filehippo.com/
Panasonic... | Answered on Aug 16, 2011
If your laptop does not have a built in FireWire port you should check if it has PCMCIA or Expresscard slot .You can use a Firewire ExpressCard to connect your panasonic device to your laptop.
http://www.siig.com/firewire-2-port-expresscard.html
Panasonic... | Answered on Aug 05, 2011
You can download the driver for your camcorder from the following link.( http://downloads.phpnuke.org/en/download-item-view-z-m-v-z-a-g/PANASONIC+NV-GS22.htm ).Please don't forget to rate me as ' helpful ' if satisfied.
Panasonic... | Answered on Jun 06, 2011
Please get it downloaded her : www.nodevice.com/driver/.../Panasonic/Camcorder.html
REgards
Panasonic... | Answered on Feb 15, 2011
You can use an USB analog to digital converter for the analog outputs or the firewire/DV/iLink connection for the digital output, with the capturing software you can then have your videos on files or disks.
Panasonic... | Answered on Feb 09, 2011
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
Panasonic... | Answered on Jan 22, 2011
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
You can download a manual for this camera by enterring the model number in this webpage.
Panasonic... | Answered on Nov 09, 2010
Panasonic NV-GS22 Mini DV Digital Camcorder Logo
26 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Video Cameras
Most Popular Question
own panasonic nv gs22
  • Video Cameras
