Compaq Marauder  19" CRT Monitor
Problems with Compaq Marauder 19" CRT Monitor?
Keep your PC up-to-date. Get a Free Scan for Compaq's latest driver updates.
Troubleshooting and Support
Solved Problems for Compaq Marauder  19" CRT Monitor RSS Feed Post a New Problem
sink problem
when moniter start then with in two hour in one or two times sink one or two seconds only above side
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Sylvania (ProView) CL2072b Circuit board...
I have discovered that the fuse on the circuit board as blown. I've jumperd it with a very tiny piece of wire wrap wire...
1 Solution
3yr old got ahold of monitor
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational...
1 Solution
Problem with monitor
My monitor looks like it has a drop shadow...all the type has a lightened verson of the text or graphics just to the...
1 Solution
I have to heat up my CRT
My problem -  Relisys TE770-RU 17'' CRT Monitor When my monitor was working correctly, I would plug in the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size19"
Color Depth24-bit (16.7M colors)
Max. Resolution1600 x 1200
Dot Pitch0.26 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputMicrophone
Dimensions
Depth18.4 in.
Height19.15 in.
Width18.24 in.
Weight58.87 lb.
Warranty
Warranty1 Year
Compaq Contact Information
Main support number800-474-6836, 800-652-6672
Sponsored Links
Loading problems.
Top Experts
Ask Me
modern Wiz
3 solutions
Ask Me
ardmax Wiz
1 solutions
Ask Me
Benimur Guru
9 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
