FixYa.com
Compaq TFT8000 18.1 in. Flat Panel LCD Monitor
All Products > Compaq > Monitors
Problems with Compaq TFT8000 18.1 in. Flat Panel LCD Monitor?
Search inside Compaq TFT8000 18.1 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for Compaq TFT8000 18.1 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
No image on screen
I recently relocated my computer and when all set up and turned on, screen is black except for a window showing this...
1 Solution
LCD Screen not getting signal
Hi, I've just bought a used Compaq TFT8000 18.1" LCD screen for my 9600/350. It's attatched to the standard...
3 Solutions
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
MONITOR REPAIR HELP
Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size18.1"
Contrast Ratio150:1
Max. Resolution1280 x 1024
Dot Pitch0.28 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Technical Features
Form FactorDesktop
Dimensions
Depth9.73 in.
Height17.02 in.
Width17.65 in.
Weight20.73 lb.
Warranty
Warranty3 Years
Compaq Contact Information
Main support number800-474-6836, 800-652-6672
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
