FixYa.com
Nikon Super Coolscan 5000 ED Film Scanner
All Products > Nikon > Scanners
Problems with Nikon Super Coolscan 5000 ED Film Scanner?
Troubleshooting and Support
Solved Problems for Nikon Super Coolscan 5000 ED Film Scanner RSS Feed Post a New Problem
vertical banding
Scanner works fine with film strips, but has vertical banding when scanning mounted slides. No banding if scanned matte...
1 Solution
Saved files appear as small dark line
I have been using the scanner for months now and have had no problem with over 2000 slides. Today, I was scanning a...
1 Solution
Drivers for Nikon LS 5000-ED
How do I get drivers for a Nikon LS 5000-ED film scanner (Windows Vista) I searched the Nikon site but can't find any...
1 Solution
Polaroid SCSI support
Hey I purchased a Polaroid Sprintscan 4000 via e-bay. It did not come with any cables or software. I found some cables...
1 Solution
Computer does not recognise scanner
I have bought one of these scanners, but despite several attempts to install it, my computer does not appear to...
1 Solution
unexpectd film scanner problem
I thank all those who responded to my previous post advising me that a flat-bed will not serve my purpose. Now I...
6 Solutions
Red Edge from Nikon 5000 ED Scanner
While I like my Nikon Super Coolscan 5000 ED, I have this persistent problem: a red "fog" sometimes is seen...
6 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Nikon Super Coolscan 5000 ED Film Scanner RSS Feed Post a New Problem
Problems with batch scans and with filing...
If I scan a batch (trip of slides) with my Coolscan 5000 ED (using a Macintosh) the first slide is scanned according to...
Post a Solution
coolscan 5000
When I scan a slide using my Nikon Coolscan 5000 into my Intel Imac it looks great. I'm archiving images at 4000 dpi and...
Post a Solution
Mac doesn't recognize SA-21 anymore
My Mac osx recognizes my CoolScan MA-21 slide mount adapter. It used to also recognize my SA-21 negative scanner. For...
Post a Solution
scanning monochrome negatives on Coolscan...
After scanning slides on my Coolscan 5000 I'm starting on my B&W negatives. I scanned the slides with 16 bit depth...
Post a Solution
NIKON super coolscan 5000 ED
There you go, Phil, we tried to make it short and sweet ! Numbers are in it, we can also send you pictures...
Post a Solution
Coolscan 5000 with SF210
We installed a Super Coolscan 5000 ED and SF210 feeder to a P4 PC with plenty of memory, CPU speed etc. Every slide we...
Post a Solution
visioneer one touch flat bed 9020 USB...
I need to get the scanner compartment open; I pushed out the cable pully by accident. I removed 4 phillips head screws...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformMac, PC
TypeFilm Scanner (35 mm)
InterfaceUSB 2.0
Optical Resolution4000 dpi
Max. Resolution (Hardware)4000 x 4000 dpi
Max. Color Depth16-bit (64K Colors)
Max. Gray Depth16-Bit (64K Gray Levels)
Technical Features
Form FactorDesktop
Scan Element TypeCCD
Light SourceRGB LED
Input TypeColor
Film Scanning Capabilities35mm Slides · 35mm Filmstrip · Positive Film · Negative Film · Color Film · Monochrome Film
Optical Density4.8 Dmax
Preview Speed11 Sec
Media
Supported Media TypePositive And Negative · APS Film · 35 mm Slides · 35 mm Film · Glass Slides For Microscopes
System Requirements
Operating SystemApple MacOS 9 · Apple MacOS X · Microsoft Windows XP Home Edition · Microsoft Windows XP Professional · Microsoft Windows 98 SE · Microsoft Windows ME · Microsoft Windows 2000 Professional
Dimensions
Depth12.4 in.
Height6.8 in.
Width3.8 in.
Weight6.6 lb.
Nikon Contact Information
Main support number1-800-NIKON-UX , 1-800-NIKON-US
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
