20 Most Recent Compaq TFT8020 18.1" Flat Panel LCD Monitor Questions & Answers
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • 8/8/2010 9:20:21 AM • Compaq TFT8020... • Answered on Aug 08, 2010
    2answers
    My compaq 610 windows logo is stuck during booting and even if I want to format it. Any help?
    Windows 7 should be the OS. If you go to safe mode, it should complete booting and then you can list the errors but I suspect there is a driver error. Maybe the wrong version in there.
    4/16/2024 12:12:58 AM • Compaq Computers... • Answered 20 hours ago
    Wife forgot the Password on Compaq F700. How can we reboot and change password, F11 will not work.
    From the Service manual https://www.manualslib.com/manual/71736/Hp-Compaq-Presario-F700.html?page=43#manual Unknown user password If the computer you are servicing has an unknown user password, follow these steps to clear the password: NOTE: These steps also clear CMOS. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the 1. computer on, and then shut it down through the operating system. Disconnect all external devices connected to the computer. 2. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and 3. then unplugging the AC adapter from the computer. Remove the battery (see Battery on page 37) 4. Remove the real-time clock (RTC) battery (see RTC battery on page 44) 5. Wait approximately 5 minutes. 6. Replace the RTC battery and reassemble the computer. 7. Connect AC power to the computer. Do not reinsert any batteries at this time. 8. Turn on the computer. 9. All passwords and all CMOS settings have been cleared. Videos as well https://www.google.com/search?q=Compaq+F700+reset+admin+password ..
    3/19/2024 5:22:06 PM • Compaq Computers... • Answered on Mar 19, 2024
    4answers
    How to download whatsapp on laptop
    As WhatsApp was originally designed for phones the process adn solution are not as straight forward as you might think, See the sites listed below: Download WhatsApp For Laptop PC Windows 8 1 8 7 Install Whatsapp http://fasttechbuzz.com/download-whatsapp-windows-8-1-7-pc-laptop-free/ download-whatsapp-for-windows-laptop-160x120.jpg If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
    1/28/2024 5:02:48 AM • Compaq Computers... • Answered on Jan 28, 2024
    Where can I find the latest BIOS and drivers for a Compaq Evo N610c laptop
    It is 22 years old and there is not support for the virus magnet that is called Windows XP!
    COMPAQ N610C QUICKSPECS Pdf Download ' ManualsLib
    ManualsLib https://www.manualslib.com > manual > Compaq-N610c View and Download Compaq N610c quickspecs online. Compaq OWNERS MANUAL Notebook N610c. N610c laptop pdf manual download. Also for: Evo n610c. Drivers https://www.google.com/search?q=compaq+evo+n610c+laptop+drivers+download 'Latest' BIOS Upgrade is 2004 (2 year support) https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade+download https://www.google.com/search?q=compaq+evo+n610c+laptop+bios+upgrade ..
    1/27/2024 11:26:47 PM • Compaq Computers... • Answered on Jan 27, 2024
    Hp compac nx6110 drivelock HDD BAY password, reset
    Hey readersFollow these steps to troubleshoot that issue. Warning -Please don't your that tip for illegal work . Its only for personal and training purpose. You can also follow my tip
    12/16/2023 6:38:16 AM • Compaq Computers... • Answered on Dec 16, 2023
    Compaq evo n115 boot from usb
    Is is probably too old to take Win 10. Also, USB support normally starts once Windows is loaded. During Boot up, it looking for a hard drive or Bootable CD Media. By default, the notebook can start only from a bootable hard drive or bootable drive medium in the notebook. https://www.google.com/search?q=Compaq+evo+n115+boot+from+usb It is 21 years old!!
    QuickSpecs
    NTS Computers Technology BV https://www.nts.nl > pdf > Compaq_EVO_N115 Compaq Evo Notebook N115. DA-11059. World Wide - Version 7 - August 12, 2002. 1. Overview. What's New. • AMD Athlon™ 4 and Duron™ processors with PowerNow ... 15 pages..
    10/17/2023 3:43:03 AM • Compaq Computers... • Answered on Oct 17, 2023
    Compaq presario desktop SR1000 wiring diagram
    You can download upgrading and servicing guide from COMPAQ PRESARIO SR1000 - DESKTOP PC MANUAL Pdf Download ' ManualsLib
    9/20/2023 5:18:41 PM • Compaq Computers... • Answered on Sep 20, 2023
    How do i verify my number on badoo
    9/13/2023 6:38:32 AM • Compaq Computers... • Answered on Sep 13, 2023
    10answers
    Best antivirus for window-7 ultimate 64-bit
    am sure it is eset nod http://www.eset.com/download
    6/12/2023 9:49:33 AM • Compaq Computers... • Answered on Jun 12, 2023
    2answers
    Out of frequency range set lower resolution
    reboot the system by pressing F8 if your using windows OS and select last good configuration.
    you can try also selecting Enable VGA mode (press F8 while rebooting and select ENABLE VGA mode).
    hope this helps, please rate.
    11/22/2022 4:45:51 PM • Compaq Computers... • Answered on Nov 22, 2022
    Compaq presario c500 dos not detect ssd hard drive
    Computer is probably too old to recognize an SSD. You may be able to find a firmware upgrade. Did you boot into the BIOS and try and find the SSD? https://www.google.com/search?q=Compaq+presario+c500+dos+not+detect+ssd+hard+drive ..
    10/26/2022 12:48:29 AM • Compaq Computers... • Answered on Oct 26, 2022
    My Compaq presario sr1313cl desktop pc, is not working a Capacitor is bad!
    Replace the capacitor.
    9/25/2022 4:31:03 PM • Compaq Computers... • Answered on Sep 25, 2022
    3answers
    I have a compaq cq5110y computer. When I push the power button nothing happens. It doesn't turn on, no fan or lights come on either. The only light that is on is on the back of the computer and it's
    It might be a connector cable between the mother board and the power supply has worked loose when the machine was moved. That blinking light appears to be on the power supply. While there might be other causes, I suspect the power supply needs to be replaced. You could take up considerable time and try to reseat everything and check all the connections and even put new thermal paste between the CPU and heatsink, but in the end, I suspect putting in a new (or used of the same type) power supply will be the fix. If the power supply has failed before damaging anything, that at least would be good news.
    8/26/2022 8:55:03 AM • Compaq Computers... • Answered on Aug 26, 2022
    I want to install xp on compaq nx 6310 give the procedure with pendrive
    2006 PC (HP.coM) 16 years old.. ouch. XP (microsoft) is now a horrible virus magnet, and there is ZERO support now, are you using the last XP earth 2020??? gee google that. 2001 to 2007 was XP rein , vista 2007 I bet there are 1millons of web site still with XP usage .(old topics) google them. but Microsoft purged theirs. it is not sold at all, so how in the world can you get the installer on any pen drive, and XP installed from CD not pen.. worst of all XP installer, can not us 99% of all USB ports and then only half after the install (unless you force them via F6 and floppy drive with xp drivers on the floppy for THIS PC) to use any relic PCs run LINUX> not XP
    7/27/2022 4:10:03 PM • Compaq Computers... • Answered on Jul 27, 2022
    My Compaq Presario Laptop won't open certain sites because they are not "secure" eg. Quora, BBC Weather, sundry health sites, etc.
    Question edited for clarity, and Maker name. Question moved from BBC Computers. BBC Weather and Quora and both secure and have an http*S* security certificate. My guess is that you have a third party security app, or worse, two of them, not understanding status or fighting with each other.
    7/12/2022 10:03:51 PM • Compaq Computers... • Answered on Jul 12, 2022
    1998 Compaq Prosignia 144 Laptop parts
    It is an obsolete dinosaur from April 1999. Put it back in the dumpster where you found it. It was in there for a reason :>D https://www.google.com/search?q=compaq+prosignia+144+parts+diagram ..
    6/21/2022 7:38:08 PM • Compaq Computers... • Answered on Jun 21, 2022
    Download free microsoft word
    2/7/2022 9:16:15 PM • Compaq Computers... • Answered on Feb 07, 2022
    Compaq TFT8020 18.1" Flat Panel LCD Monitor Logo
    Popular Tags
    2 questions posted
    Top Compaq Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ExpressFiX
    ExpressFiX
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
    View Most Popular
    • Compaq Computers & Internet
    Most Popular Question
    signal outof range
    • Computers & Internet
