20 Most Recent Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Questions & Answers
This may be a somewhat unusual suggestion, but have you thought of taking it to be serviced ?
Panasonic... | Answered on Sep 15, 2017
This is just a wild guess, you understand, but maybe it could be fixed by getting it serviced ?
Panasonic... | Answered on Aug 12, 2017
when you press the reset button, the first thing the camera does is a self-test of the mechanism. "cylinder lock" is displayed when the video rec/playback head drum (cylinder) motor does not operate or operates intermittently. this is usually caused by a poor connection on the small cable that connects the head drum assembly with the main control circuitry inside the camera. disassembly of the camera is necessary to clean and re-seat this cable, along with the cable that carries the video information to the head drum. I have repaired several of these cameras with this problem. it's not difficult, but an inexperienced repair person can do more damage than help if they're not careful.
Panasonic... | Answered on Aug 31, 2016
Look for lens repair shops online.
Panasonic... | Answered on Oct 01, 2014
Try to remove the battery, after switching off, then give it 2 minutes, reboot.....if that fails then maybe the charge is too low for it to start...so charge the battery. If that fails then you have a dead machine!
Panasonic... | Answered on Jun 17, 2014
I have the same problem .How to resolve it?
Panasonic... | Answered on Dec 07, 2012
On the cassette shell is a small sliding door that prevents recording, move it to the record position.
The idea is to protect a valuable tape from being recorded over.
Panasonic... | Answered on Mar 28, 2011
Exact. Firewire is a protocol. Usb is a different one. Both has nothing in common. Also if you dont have firewire it usually also means you have older computer that may have trouble to handle firewire big video files anyway. Video editing requires dual core cpu and firewire cards, and 30 gig per hour of storage...
Panasonic... | Answered on Aug 28, 2009
set the camera audio switch to line, not mic feed. This switch is on the camera. Adjust the audio gain to -60db in the menu settings.
Panasonic... | Answered on Aug 10, 2009
make sure that there is no tape in the camera.
Panasonic... | Answered on Apr 17, 2009
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
Panasonic... | Answered on Mar 02, 2009
do u have a laptop with firewire port 1394 and port on the Camera it is there ,u can easily connect thru fire wire link with 4 pin cable cable buy a cheap one from store like 10 $ there is no need for buying a branded one bcoz quality is not compromised in any way this is digital signal, if u dont have the laptop with firewire then u have to spend more on PCMCIA FIREWIRE CARD for it or PCI firewire card for desktop which ever u like and then u also need a software to capture the video which i think u have in ur pc , no need for drivers just connect and it will be auto available in the capture devices list of the capturing software, just go and do it
bcoz ur camera is MINIDV TAPE there is no other option to get ut footage on PC for editing
pls rate me if u find me fixya problem
contact me for further help
Panasonic... | Answered on Feb 25, 2009
Couple of questions:
Did you record/dump using a battery that may have been low on power?
Are you using a fire wire or USB cord?
Panasonic... | Answered on Jan 30, 2009
sounds like the dvc7 needs a cleaning tape.
Panasonic... | Answered on Nov 24, 2008
Hi!
The DVC7 has a 43mm filter thread on its lens. Depending on your Bower's thread size, you may need a step-up or step-down adapter ring to fit it to the DVC.
After checking if you have your sizes correct, you need to remove the DVC7's lens hood. After that, it's just a matter of screwing the wide angle lens to the DVC's lens.
Hope this helps!
Panasonic... | Answered on Nov 14, 2008
try getting a head cleaner for the camera and see if that works. If not then moisture mas seeped into the cameras circuits and caused a short circuit. seems like the only way to fix it, is to have it sent back to the manufacturer for repair.
Panasonic... | Answered on Jun 30, 2008
the stripes are caused from one of the heads on the dd cylinder not updating. you need to stick a head cleaner in, if that does not solve the problem then either the head is going need a thorough clean or it is damaged. it will need replacing.
Panasonic... | Answered on Jun 09, 2008
Panasonic Proline AG-DVC7 Mini DV Digital Camcorder Logo
38 questions posted
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
View Most Popular
AG Panasonic
  • AG Panasonic
Most Popular Question
panasonic
  • Video Cameras
