20 Most Recent
Panasonic PanaSync SL70 (White) 17" CRT Monitor Questions & Answers
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
2/20/2008 4:47:06 AM •
Panasonic...
Answered
on Feb 20, 2008
Panasonic cf-19 Enter key not working
- Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM •
Panasonic...
Answered
on Jun 16, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM •
Panasonic...
Answered
on Apr 01, 2023
Panasonic cn-mw100d will not turn on but power is coming to unit
The Panasonic CN-MW100D is a portable navigation device. If it's not turning on even though power is coming to the unit, it could be caused by a few different things.
- First, check that the power cord is securely plugged into both the device and the power source.
- Second, check the battery level, if the device has a battery, if the battery is dead, replace the battery or charge it.
- Third, check the fuse, if the fuse is blown, replace the fuse.
- Fourth, try doing a hard reset by holding down the power button for 10 seconds.
- If none of the above steps resolve the issue, then the problem may be with the internal hardware of the device and it may need to be repaired or replaced.
1/31/2023 8:29:42 PM •
Panasonic...
Answered
on Jan 31, 2023
