Compaq V700  17" CRT Monitor
Problems with Compaq V700 17" CRT Monitor?
Keep your PC up-to-date. Get a Free Scan for Compaq's latest driver updates.
Troubleshooting and Support
Solved Problems for Compaq V700  17" CRT Monitor RSS Feed Post a New Problem
Dead Monitor
Hi, I bought my parents an HP computer for Christmas and now, only 7 months later, the monitor stopped working. w1907...
1 Solution
i need it's schematic
i need the comaq v700 schematic
1 Solution
Compaq v700 monitor + O2
Hi, I'm currently having display problems with my o2 and compaq monitor, my monitor displays more green then normal...
6 Solutions
CRT Monitor-Compaq presario VM700
I am trying to fix a friend's computer and suddenly the monitor went into sleep mode (aas indicated by the light on the...
1 Solution
GeForce Pro & NEC V700 problem!!!!
Just bought myself the 3D Blaster GeForce Pro (DDR), only to find out that it's not compatible with my NEC V700...
2 Solutions
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
Unsolved Support Problems
Unsolved Problems for Compaq V700  17" CRT Monitor RSS Feed Post a New Problem
black bar at the end of my compaq v700...
i get a horizon flikkering black bar at the bottom of my compaq v700 monitor, when i startup my computer. if it is a...
Post a Solution
Faint coloring.
Hello, i am having a problem with my compaq v700 and was wondering if you could help. well the problem is that the...
Post a Solution
monitor won't go on
monitor won't go on when connected also the power supply is different it was supposed to be a 400 volt and the one that...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size17"
Max. Resolution1600 x 1200
Dot Pitch0.22 mm
Monitor TypeCRT
Technical Features
Form FactorDesktop
Dimensions
Depth16.98 in.
Height17.49 in.
Width16.71 in.
Weight40.79 lb.
Warranty
Warranty3 Years
Compaq Contact Information
Main support number800-474-6836, 800-652-6672
Sponsored Links
Loading problems.
Top Experts
Ask Me
tomj23 Guru
4 solutions
Ask Me
Rosley Guide
1 solutions
Ask Me
basscleff Wiz
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
