20 Most Recent Jeep 2004 - Liberty Questions & Answers
Where is the trans fluid pressure sensor on a 2004 jeep liberty
googtrans fluid pressure sensor on 2004 jeep libertyle-
9/9/2016 10:34:28 PM • Jeep 2004 -... • Answered on Sep 09, 2016
Jeep liberty front brakes lock on ?
is it both wheels? check the line going to the wheel or wheels that are locking up, if there is any sign of a fluid leak replace the line. when they leak they will apply enough pressure to lock the brake, but will not release the pressure there for it stays lockedRandy
8/4/2012 12:16:17 PM • Jeep 2004 -... • Answered on Aug 04, 2012
2014 Jeep Wrangler. Boss car audio head unit won't power on after vehicle has been shut off.
U need to pu t the ignition 12v wire from head unit and wire in to the 12v constant wire from your battery
6/28/2022 10:31:28 PM • Jeep Car Audio &... • Answered on Jun 28, 2022
I have a 2011 Jeep wagler, the cd player just keeps ejecting any cd I try . I bought a cd cleaner cd and it only ejects that as well in at a lost on what to do can anyone help
you have to remove the radio from dashboard....open the top cover and clean the lazer lens with soft cloth and white spirit....
9/13/2019 10:57:27 PM • Jeep Car Audio &... • Answered on Sep 13, 2019
Why won't my minutes change or adjust on 2014 Jeep Compass digital clock.
Here is a video that may be of some assistance to you.
5/7/2019 9:13:59 AM • Jeep Car Audio &... • Answered on May 07, 2019
2000 jeep cherokee xj left rear door wont open from either side. any suggestions?
you need to remove the interior panel and check door handle might need to reconnect
3/24/2019 5:22:37 PM • Jeep Car Audio &... • Answered on Mar 24, 2019
Where do I find the 6 disc changer in my jeep liberty 2006
Try the trunk ..under the front seats... glove box does it have one fitted from new it might not
10/8/2018 9:01:01 PM • Jeep Car Audio &... • Answered on Oct 08, 2018
Hi my 2008 liberty am fm cd radio has just started cutting out, the audio part stays on for a while then stops and when i turn jeep off the audio comes back on any ideas.thks
stock radio? no photo of it so how can I guess? ok , so do tell what works and not first. all 4 speakers cut out. left right front and rear? all modes am fm cd car drives ok, day and night all other features work on car. yes, then the audio system head end (or amp if opted) has problems. this can be a loose or bad fuse to it, or wires to it hacked, for sure if not stock, yah. all radios can be bench tested. a speaker. and antenna or CDDA cd disk, store bought. sure can, done a vast numbers like that, step one, is it just a radio or radio with external amp? step 2 is power to radio good, a voltmeter checks that easy. if power is good to it then the unit is bad. power means the power wire, and ground good. 12vdc key on. is good 0v is bad. the other power wire is memory only.
1/17/2017 9:09:18 PM • Jeep Car Audio &... • Answered on Jan 17, 2017
I just bought a new radio for my jeep and it says it is SiriusXM ready. Does this mean all I have to do is get a plan?
No this means you can control Sirius radio with your car stereo, but you still require A sirius external device. In other words your looking for simply a Sirius add-on Kit for your stereo, If the kit comes with controller, which most do, then the fact your new car stereo is Sirius Ready, makes the Sirius controller obsolete. I hope this helps. Carlos Q
4/5/2015 12:37:50 AM • Jeep Car Audio &... • Answered on Apr 05, 2015
Jeep 2004 - Liberty Logo
5 questions posted
Top Jeep Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jeep Car Audio & Video
Most Popular Question
trans fluid pressure sensor 2004 jeep
  • Car Audio & Video
