FixYa.com
Hansol H711 SB  17 in. Flat Panel LCD Monitor
All Products > Hansol > Monitors
Problems with Hansol H711 SB 17 in. Flat Panel LCD Monitor?
Search inside Hansol H711 SB 17 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for Hansol H711 SB  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
Monitor Problem
i have a Hansol H711 TFT monitor and it is displaying a message saying "Out of Range 48.0k/ 50.0, 73M, Change...
2 Solutions
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
MONITOR REPAIR HELP
Hi I would like to appreciate for your help I have got an Acer monitor model G781 CRT Type its switching power...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
Need Data Sheet for M52327SP I.C.
Monitor is a 15 Inch MAG Inovisions. This chip is a Mitsubishi M52327SP Triple Video Amplifier I.C. I suspect. It is on...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Hansol H711 SB  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
I have a Hansol H711 LCD monitor not...
This monitor will turn on for just a second, flash the screen as it should - then turn black. The power is still on,...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio350:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.26 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time40 ms
Technical Features
Form FactorDesktop
Dimensions
Depth7.72 in.
Height17.73 in.
Width16.78 in.
Weight14.11 lb.
Warranty
Warranty3 Years
Hansol Contact Information
Main support number714-680-9910
Email supportsupport@hansol-us.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
