20 Most Recent Dell UltraScan 1600HS D1626HT 21" CRT Monitor Questions & Answers
2answers
Horizontal / vertical deflection failure
The solution to this problem was to replace the sony part #CXA2043Q on the D Board.
Oldpilot
8/1/2011 12:26:24 AM • Dell UltraScan... • Answered on Aug 01, 2011
2answers
My dell monitor turns yellow
Under options for the monitor try degauss. This will de magnetize the monitor which may help.
Don't try to fix anything on the inside because old CRT monitors have dangerous capacitors
that can cause an electrical shock even when unplugged. Personally I would recomend getting
a new flatscreen. In the US they are pretty cheap even for a large screen, and burn much less electricity and look much better. If looking for a new monitor check online usually much cheaper
than big box stores. Newer models also have better refresh rates than the 1st ones that came out
so if your a gamer the performance of most newer flatscreens is pretty good.
5/16/2011 6:35:05 AM • Dell UltraScan... • Answered on May 16, 2011
2answers
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
4/19/2024 6:52:18 PM • Dell Computers &... • Answered 7 hours ago
3answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
4/19/2024 3:11:57 PM • Dell Computers &... • Answered 11 hours ago
2answers
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Are there any other ways to bypass the log on screen on a dell inspiron 3052 so i can factory reset it
Windows can be accessed renaming two files. computingterror.blogspot.com/2014/03/hack-windows-7-login After that being done you should run the Support Assist OS Recovery from DELL dell.com/support/kbdoc/en-us/000177401/restore-your-system-using-dell-supportassist-os-recovery Windows 10 can renew itself, without Windows Setup on a USB medium.
10/23/2023 4:55:37 AM • Dell Computers &... • Answered on Oct 23, 2023
Alpha Lansing ACS400; Dell Inspiron 3020 Windows 11. PC won't recognize speakers. No sound.
Go here [9 Ways] How to Open Windows 11 Device Manager Quickly? - MiniTool Remove all device under sound video and game controllers, and audio in and out.. Then reboot your computer.
10/4/2023 10:39:39 PM • Dell Computers &... • Answered on Oct 04, 2023
I've got a dell inspiron 20 model 3052 series how do you reset it to factory settings or reset the password thought it was a monitor any help would be very greatfull!
Unfortunately, resetting a Dell Inspiron 20 model 3052 series to factory settings requires you to use a recovery disk or USB drive, as the system does not include a built-in resetting option. To reset your password, you will need to use a password or recovery disk. You can create a password or recovery disk using the Dell Support website.
9/2/2023 11:52:56 AM • Dell Computers &... • Answered on Sep 02, 2023
Dell Precision M4600 will not go past POST, Stops at Preparing to enter setup
If your Dell Precision M4600 is getting stuck at the "Preparing to enter setup" stage during POST, you might want to try a few troubleshooting steps. 1. **Power Cycle:** Disconnect the laptop from the power source, remove the battery (if possible), and hold down the power button for about 15 seconds. Then, reconnect the battery and power source and try booting again. 2. **Reset BIOS:** You could try resetting the BIOS settings to their default values. To do this, look for a small button battery on the motherboard. Disconnect the laptop from power and remove the battery. Press and hold the power button for a few seconds to discharge any remaining power. Then, locate the battery, remove it for a minute or so, and put it back. This will reset the BIOS settings to default. 3. **Update BIOS:** If the issue persists, you might need to update the BIOS. Check the Dell support website for your laptop model and download the latest BIOS update. Follow the instructions to update the BIOS. 4. **Check Hardware:** If the issue is not resolved, it might be related to a hardware problem. Try removing and reseating components like RAM, hard drive, and any expansion cards. 5. **External Devices:** Disconnect all external devices (USB drives, external hard drives, printers, etc.) and try booting again. Sometimes, a faulty external device can cause boot issues. 6. **Diagnostic Lights:** Dell laptops often have diagnostic LED lights that provide information about hardware issues. Check the user manual for your laptop model to interpret these lights. If none of these steps resolve the issue, it might be worth seeking professional assistance or contacting Dell support for further guidance.
8/23/2023 8:49:51 AM • Dell Computers &... • Answered on Aug 23, 2023
Empowering technology windows xp
We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update...We recommend upgrading to another level of operating software, or perhaps windows 7 windows 8 is that they are available for more security and development update ... windows 7 upgrade will soon be without ...
8/12/2023 6:02:40 PM • Dell Computers &... • Answered on Aug 12, 2023
Im trying to factory reset my dell inspiron 1100
Maybe this will help. https://www.dell.com/support/kbdoc/en-us/000192008/how-do-i-erase-data-from-my-hard-drive-or-mobile-device-before-trade-in
8/8/2023 8:57:40 PM • Dell Computers &... • Answered on Aug 08, 2023
Dell UltraScan 1600HS D1626HT 21" CRT Monitor Logo
Popular Tags
4 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
UltraScan Dell
  • UltraScan Dell
Most Popular Question
horizontal vertical deflection failure
  • Computers & Internet
