Sony Personal Entertainment SDM-V72W  17.1 in. Flat Panel LCD Monitor
Problems with Sony Personal Entertainment SDM-V72W 17.1 in. Flat Panel LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for Sony's latest driver updates.
Troubleshooting and Support
Solved Problems for Sony Personal Entertainment SDM-V72W  17.1 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
what do i do
screen is nothing but lines vertically laid on full screen is it junk
1 Solution
HELP!! 1280x768 supported driver needed
I just purchased the wide screen LCD from sony (SDM-V72W) but I soon found out there is a serious problem with newer...
3 Solutions
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Acer Aspire 1710 laptop monitor is down
Hi, monitor on my laptop went black in a moment. Looks like computer is continuing to work. When making a closer look at...
1 Solution
Monitor trouble
I have a westinghouse monitor and we had a wind storm .My server went down for about 5 minutes and when it did my...
1 Solution
L222WT flatron 21.6 monitor is not working
When the monitor is turned on, the LG symbol/logo appears as if it will then go to the Windows Vista page. Instead,...
1 Solution
bzzzing noise coming from monitor
my monitor is making noises, like an electrical bzzz. Could it be a corrupt profile or is it hardware? other than that,...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio16:9
Size17.1"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness450 cd/m
Max. Resolution1280 x 768
Dot Pitch0.29 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time22 ms
Viewable Picture Size17.1 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputStereo Mini-Connector
Regulatory ApprovalFCC Class B · Energy star
Input DeviceRemote Control
Synchronization Range - Horizontal28 - 70 kHz
Max. Viewing Angle - Horizontal150
Max. Viewing Angle - Vertical120
Native (Recommended) Resolution1280 x 768
Synchronization Range - Vertical48 - 85 Hz
Dimensions
Depth7.21 in.
Height16.9 in.
Width18.6 in.
Weight13.01 lb.
Warranty
Warranty3 Years
Sony Contact Information
Main support number800-488-7669
Sponsored Links
Loading problems.
Top Experts
Ask Me
najah Wiz
2 solutions
Ask Me
Dos9 Wiz
2 solutions
Ask Me
jomama550 Wiz
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
