Sony SDM-HS75  17" LCD Monitor
Problems with Sony SDM-HS75 17" LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for Sony's latest driver updates.
Troubleshooting and Support
Solved Problems for Sony SDM-HS75  17" LCD Monitor RSS Feed Post a New Problem
Sony SDM HS75 Monitor
My monitor keeps going blank after the computer has been switched on for a little while, it comes back on then back off...
1 Solution
Sony SDM-HS75 tft lcd monitor
The monitor, when plugged in goes dark, after about 30 seconds. I can turn it off and then on only to have it be normal...
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
monitor takes 1/2 hour to warm up
when switching on my computer it takes at least 1/2 hr for the monitor to show anything, once the images appear...
1 Solution
Frequency problem of LCD monitor
I am using fedora core 6 with nvidia GF 7200GS graphichs card.But LG Flatron L1730S giving the error out of range...
1 Solution
Connecting my LCDTV upto my Computer
I'm trying to connect my LCD Monitor to my computer and when i follow the instructions in my manual it tells me to go...
1 Solution
HCL Monitor type HCM580M display problem
after complete installation of Windows XP, display is not coming on monitor while power switch is ON, if we turn OFF...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalUL · cUL · C-Tick · Energy star · FCC · IC
Synchronization Range - Horizontal28 - 80 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1280 x 1024
Synchronization Range - Vertical48 - 75 Hz
Dimensions
Depth5.48 in.
Height13.7 in.
Width15.3 in.
Weight11.0 lb.
Warranty
Warranty3 Years
Sony Contact Information
Main support number800-488-7669
Sponsored Links
Loading problems.
Top Experts
Ask Me
Zwarrior Guru
1 solutions
Ask Me
Sunil Pan Wiz
2 solutions
Ask Me
Drummerni Wiz
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
