20 Most Recent
JVC GR-DX28 Mini DV Digital Camcorder Questions & Answers
Hi ,
i have a
there is no driver available on the manufacturer site ..but if you have a ieee fire-wire or a usb cable for connection you can try to import from the camera into windows movie maker (windows built program) cause in this case I suspect that no driver is needed..
Also if your camera uses a card for storage you can actually just connect it ..and look in the my computer folder to see if the card is seen as a removable device ..and the videos are stored there ...if so ..just copy them into computer ..
Also if you use a card for storage ..but the card is not seen via usb cable ..just insert the card into a card reader..and retrieve the files..
Anyway ..they do not supply any driver ..so I guess it may be built in windows..or ..needs a capture card ...or manager ..
Condensation paused
try to shoot medium hot air in the camera with an air
dryer watch for the plastic if you to closed it will be deformed/until the dew sensor go off /that will
removed all humidity inside and try to store in a dry place/
hope that will help you
I have a jvc GR-DX28
Hi there, please try to reset the camcorder and then tryo to use , But i guess you have not get a solution. Because,It does not matter what brand of tapes you use in any camcorder. (thats like saying this car only runs on shell unleaded, any other petrol wont work.)
I have been a camo for many years and there are tapes that perform better than another but they all work. I too have a problem with "E06" I am sure it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.I suggest you take it to the nearest dealer and get it fixed.
Thanks & waiting for your feedback.
Missing spring on cassette mech. and condensation opertion paused
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
