FixYa.com
Sony CPD G500  21" CRT Monitor
All Products > Sony > Monitors
Problems with Sony CPD G500 21" CRT Monitor?
Troubleshooting and Support
Solved Problems for Sony CPD G500  21" CRT Monitor RSS Feed Post a New Problem
g500 driver
where I can find the original driver?
2 Solutions
Sony CPD-G500
Hoping I can get a hand on this. CRT looks overdriven. I've played with some monitors in the past that had a 'picture'...
3 Solutions
CPD-G500
Whenever I turn off my monitor for, let's say, more than 3 hours, it displays what appear to be 10-15 lines running...
1 Solution
Broken power button
I came across several of these Sony G500 21" crts. They had the g2 brightness problem. I fixed three of them using...
1 Solution
SONY CPD-G500, DO NOT HAVE HIGH TENSION,...
HELLO FOLKS, I HAVE A SONY MONITOR CPD G-500, WHEN A TURN ON THE POWER, THE LED KEEPS GREEN, AFTER FEW SECONDS BECOME...
1 Solution
sony g500 asus v6600 problem
Hi - I have an asus v6600 deluxe (agp) and a new sony g500 monitor. whenever i come out of my screensaver, or...
1 Solution
Sony G500 brightness problem
I have a Sony CPD-G500 monitor which was, unfortunately, dropped on the floor (!). This blew the power supply, which...
2 Solutions
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio4:3
Size21"
Max. Resolution2048 x 1536
Dot Pitch0.23 mm
Monitor TypeCRT
Viewable Picture Size19.8 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalUL · FCC Class B · CSA · TUV-GS · DHHS · TCO-99 · MPR-II
Synchronization Range - Horizontal30 - 121 kHz
Native (Recommended) Resolution1600 x 1200
Resolutions supported1600 x 1200 · 2048 x 1536
Synchronization Range - Vertical48 - 160 Hz
Dimensions
Depth18.52 in.
Height18.91 in.
Width19.7 in.
Weight68.36 lb.
Warranty
Warranty3 Years
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
