FixYa.com
iiyama Vision Master Pro 454  19" CRT Monitor
All Products > iiyama > Monitors
Problems with iiyama Vision Master Pro 454 19" CRT Monitor?
Troubleshooting and Support
Solved Problems for iiyama Vision Master Pro 454  19" CRT Monitor RSS Feed Post a New Problem
iiyama Pro 452 clicking sound during...
iiyama pro 452 - when first turning on the monitor, and during bootup, the screen remains blacked-out with a load...
STAFF 2 Solutions
iiyama HM903DTA 19" Vision Master 454
Hi~ Right, I'm having the similar problems with others on this board. Although I start up my PC and my Monitor...
1 Solution
monitor
unit powers up ok,steady green light, when the computer is started monitor display blinks on and off (but no detail) as...
1 Solution
Display completely flipped to side
1 Solution
Problem with the monitor
I have red green rectangles spread across the monitor, I tried formatting my pc, I also tried restoring default factory...
1 Solution
screen menu displays locked & unlocked
Hi i am a small techni,i have got problem in samtron 56v.It displays locked and unlock,if i press exit also it does not...
1 Solution
A pink vertical line appears suddenly on...
My Samsung SyncMaster 740N monitor is just a week old, and a pink vertical line appears on the screen suddenly. It...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size19"
Max. Resolution1920 x 1440
Dot Pitch0.24 mm
Monitor TypeCRT
Viewable Picture Size18 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputStereo Mini-Connector
Regulatory ApprovalCE · UL · FCC Class B · CSA · TUV-GS · DHHS · PTB · TCO-99 · MPR-III
Synchronization Range - Horizontal30 - 132 kHz
Resolutions supported1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 1920 x 1440 · 1600 x 1280
Synchronization Range - Vertical50 - 200 Hz
Dimensions
Depth17.61 in.
Height17.73 in.
Width17.73 in.
Weight51.82 lb.
Warranty
Warranty3 Years
iiyama Contact Information
Main support number800-594-7480
Support FAX336-852-6790
Email supportservice.us@iiyama.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
