FixYa.com
Sony SDM-HS95P/S  19" LCD Monitor
All Products > Sony > Monitors
Problems with Sony SDM-HS95P/S 19" LCD Monitor?
Search inside Sony SDM-HS95P/S 19" LCD Monitor Knowledgebase
Troubleshooting and Support
Solved Problems for Sony SDM-HS95P/S  19" LCD Monitor RSS Feed Post a New Problem
Pop up menu won't go away.
I have had this monitor for over 3 years. Never had a single problem with it. Then tonight out of no where a pop up from...
1 Solution
pink monitor
I've swopped out my pinkl monitor screen and screen is still pink on the replacement. What can I do to fix?
1 Solution
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio550:1
Brightness500 cd/m
Dot Pitch.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time12 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalUL · cUL · Energy star · FCC
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal28 - 80 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1280 x 1024
Synchronization Range - Vertical48 - 75 Hz
Dimensions
Depth5.7 in.
Height16.5 in.
Width17.1 in.
Weight13.2 lb.
Warranty
Warranty3 Years
Sony Contact Information
Main support number800-488-7669
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
