20 Most Recent Cyber Acoustics CA-2016 Computer Speakers Questions & Answers
Distorted speaker sound
It might be that you have a bad solder joint somewhere. Try shaking the speaker when playing, but be careful not to short the speaker wire connections. If it returns to normal at any point this is a dry joint somewhere.
6/2/2017 1:14:19 AM • Cyber Acoustics... • Answered on Jun 02, 2017
I have a dell pc in a docking station. I am using
if you mean that you cant get any sound on your computer control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers hope this helps
12/9/2010 10:44:49 PM • Cyber Acoustics... • Answered on Dec 09, 2010
I cant install them?
The CA-2016 desktop 2-piece system it is a USB powered amplifier that draws the power through a USB cable. No batteries or AC power source/wires are required which leaves the desk top clean. The speaker system is magnetically shielded and has a LED power indicator. This being said setup the speakers plug in the USB cable, notice if the LED power indictor light is on. Adjust volume control on speakers and on your computer ( make sure your not muted ). PC's have a lot of different media players that can and will effect the volume control so if one or more of those items are adjusted to low volume or muted, there will be little to no output to your speakers.
12/5/2010 11:14:43 PM • Cyber Acoustics... • Answered on Dec 05, 2010
Hi;My cyber acoustic speakers worked on my other
If you are connecting them to a diferent sound card , make sure they have drivers installed...Connect wires properly , and it should work fine.
goodluck :D
12/29/2009 11:14:22 PM • Cyber Acoustics... • Answered on Dec 29, 2009
2answers
Computer speaker installation
I may have disconnected them and I need the disc to download so they will work- they worked earlier today and now they do not
9/29/2008 12:06:51 AM • Cyber Acoustics... • Answered on Sep 29, 2008
Computer Speakers
Try and plug your speakers into a friend's computer and check if they work. If they don't, then the speakers are fried, probably because of a voltage surge when the power went out. If they do work on your friend's computer then you most likely have a bad port on your computer because of the power surge.
12/14/2007 5:13:33 AM • Cyber Acoustics... • Answered on Dec 14, 2007
0answers
Why does my sub woofer not work
it could be a connection from not grounded to your aux cords being crimped and messed up could be amp or could be a setting on your radio..
2/13/2015 10:53:18 PM • Cyber Acoustics... • Answered on Feb 13, 2015
How to use them in India? Got them from US
What model?
4/27/2014 6:12:23 AM • Cyber Acoustics... • Answered on Apr 27, 2014
Cyber Acoustics CA-3618 subwoofer cuts in and out.
Crackling noise and cut outs generally mean that the speaker is torn, or the cone is separated from the driver. This means the speaker is broken irreparably. It sells for $40 now, which means it is not worth fixing. These low cost speakers are built to not be taken apart.
4/7/2014 4:20:14 AM • Cyber Acoustics... • Answered on Apr 07, 2014
Cyber Acoustics CA-2016 Computer Speakers Logo
13 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
computer speaker installation
  • Audio Players & Recorders
