20 Most Recent
Sony Handycam DSR-390L DV Digital Camcorder Questions & Answers
DSR 390 error
If you put it down on the sand you probably got moisture or sand in it or possibly both if you put it down on a towel you may have gotten sand in it, try pulling the camera apart carefully and cleaning the chip boards unfortunately salt water will actually eat the protective coating on the boards and salty sand is worse most times you can't save them, sorry hope it works for you though
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
