20 Most Recent
JVC GR-DVX7 Mini DV Digital Camcorder Questions & Answers
E304
it sounds like moisture. leave the door of the cassette mechanism open in a warm dry room for 24 hours.
then try to operate the eject mecanism as normal.
Sharp VL-S1H camcorder
http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/Viewcam/VLRD1H/VLRD1H-034.pdf
this is for a VL-RD1H, but is the closest i could find available, hopefully most is the same.
Hope this helps, post again if not :)
Power switch
The power switch is only supplied with the operation unit (camera/off/vtr assembly). You can find this replacement part
here.
Transferring video footage to dvd
I am trying to find out how I can transfer the video footage from my camcorder tapes onto my laptop to then store as DVD's. Is it possible? how can free down load driver frmo website is it also posible?
Gr-dvx7 jvc lcd screen is just white?
If the view finder shows the same white display. You probably have display circuit problem in the camera. Faulty CCD chip usually shows Black screen so it probably board problem or a connector problem. If you see an image through view finder then you may have defective connection from board to LCD assy. Either way it need to be looked at by a trained technician. Good luck.
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
