20 Most Recent Sony Handycam DCR-TRV240E Digital Camcorder Questions & Answers
Firstly resetting your camera will not delete your recording.Try re-installing your software then try capturing. Secondly play the tape on your camera then engage the capture button on your computer
Sony Handycam... | Answered on Apr 20, 2017
After looking up the error code C:31:22, I saw all of the solutions for slapping the side of the camera. Slapped it 4 times, then the error code switched to C:31:23. Same solution... Whacked it 4 times, then the error code switched to C:31:40. Again, whacked it 4 times. Opened it up, turned it upside down and a rubber roller dropped out of the camera. I could see where it went, snapped it down on its metal peg and it works fine. Looks like its the rubber rollers that guide the tape that gets stuck. Before whacking it, make sure the RUBBER roller moves freely. Good luck!!!
Sony Handycam... | Answered on Jul 26, 2010
Yes there is a driver go to http://support.sony-europe.com/DIME/camcorders/D8/D8.aspx?l=en&m=DCR-TRV240E and download the driver for vista 32bit... Unzip the files ... you will find a set up file DONT DOUBLE CLICK IT Just like I did Follow the instructions in the instalation list and you will find it works PERFECTLY....
Sony Handycam... | Answered on Jan 09, 2010
Please see the detail below for the said error code C:31:40eb129ed.jpg
According to the symptom this show that there are two faults
1- Mechanical adjustment is out.
2- Head is durty.
Solution:
1- Mechanical adjustment is required of tape loading section.
2- Need head cleaning.
Please contact any expert nearby to yoy to fix the problem, because mechanical adjustment is not an easy task that's why prefer repair man.
Thanks for using fixya.
Sony Handycam... | Answered on Jun 16, 2009
Hi Jazzy,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Hi Tariq,
Hi Jeany,
Please see the detail below for the said error codes C31:23 & C31:22
do you have the wondershare dpg converter registration code? can you give it to me on [email protected] \r\n
thank you
Sony Handycam... | Answered on Jun 14, 2009
After not using my camera (Sony HVR-V1U) for one week, I took it out for an assignment but the error keeps coming up C:31:40 asking me to eject the cassette. The camera never gave me problems before this.I have tried smacking it at the bottom with the flat of my hand, flowing it with a hair dryer, shaking it, opening the cassette door for hours but nothing seems to work. The sony technician says I may have to send it in for repairs can any one help before I have to resort to this?
Sony Handycam... | Answered on Oct 11, 2008
Hi! If the images you are capturing are hazy with zig zag colors etc...the imaging IC is faulty.If the problem in Display unit only but the captured image is OK when you transfer the same to PC..then LCD may be having problems. We can help you in spares of Sony and we can also offer the service manual. Kindly let me know after your examination. Regards, Sivaram.V Videolabs
Sony Handycam... | Answered on Aug 07, 2008
The symptoms you told shows the defect in control jog switch and its available as "control switch block". If you wish, I can give you its part number.
Sony Handycam... | Answered on Jun 23, 2008
Usually letting the unit open for a day in a dry environment is enough to resolve this problem. If you have done this and still get the message your moisture sensor is bad and needs replaced. It is in the vicinity of the video drum assembly. I don't know if you are capable of making this repair but any good repair shop should be able to fix it for less than $100 US. Good luck.
Sony Handycam... | Answered on Jul 20, 2006
It could very well be a blown fuse, and if you have some experience working inside these devices you can open it up, give it a try, and you might save a little on repair costs. Pull out the power supply board, and look for any obvious burns. Fuses are marked with a prefix PS on sony devices. check if they transfer current, if not - order new ones and see if replacing them solves your problem, or if it spread further. Good luck
Sony Handycam... | Answered on Apr 23, 2006
Try Googling (sony)(CCD-TRA425E)(manual) without parens.
Sony Handycam... | Answered on Dec 21, 2017
Sony Handycam DCR-TRV240E Digital Camcorder Logo
28 questions posted
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
sony dcr trv350 c31 23 c31 22 flashing
  • Video Cameras
