IBM 15 in. Flat Panel LCD Monitor
Problems with IBM 15 in. Flat Panel LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for IBM's latest driver updates.
Troubleshooting and Support
Solved Problems for IBM 15 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
sink problem
when moniter start then with in two hour in one or two times sink one or two seconds only above side
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Sylvania (ProView) CL2072b Circuit board...
I have discovered that the fuse on the circuit board as blown. I've jumperd it with a very tiny piece of wire wrap wire...
1 Solution
3yr old got ahold of monitor
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational...
1 Solution
Problem with monitor
My monitor looks like it has a drop shadow...all the type has a lightened verson of the text or graphics just to the...
1 Solution
I have to heat up my CRT
My problem -  Relisys TE770-RU 17'' CRT Monitor When my monitor was working correctly, I would plug in the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio4:3
Size15"
Color Depth24-bit (16.7M colors)
Max. Resolution1024 x 768
Dot Pitch0.30 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Viewable Picture Size15 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · UL · FCC Class B · CSA · NOM · Nemko · VCCI · TCO-95 · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · SEMKO · MPR-II · GOST-R · MPR-III · DEMKO · FIMKO · SASO
Synchronization Range - Horizontal31 - 70 kHz
Resolutions supported800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 720 x 400 · 640 x 350
Synchronization Range - Vertical50 - 160 Hz
Dimensions
Depth7.96 in.
Height14.61 in.
Width15.79 in.
Weight14.33 lb.
Warranty
Warranty3 Years
IBM Contact Information
Main support number1-800-IBM-4YOU / (1-800-426-4968)
Email supportaskibm@vnet.ibm.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
skotkolr Wiz
13 solutions
Ask Me
Silverdra Wiz
5 solutions
Ask Me
viziks Wiz
15 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
