20 Most Recent
Sony Handycam CCD-TRV815 Hi-8 Analog Camcorder Questions & Answers
Sony CCD-TR805E Auto focus and manual focus failure.
This is a new one on me, but a few things...
Has this ever been dropped? It sounds like the optical block has internal damage. I can understand the lack of auto-focus, but not manual. If you look down the lens, you should be able to see movement as you zoom and focus. Can you see movement at all?
Dan
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
Blue screen on TRV260 playback
TRV260 nail-polish head attack:
eek.
Acetone is a powerful solvent capable of dissolving plastic parts, plastic gears, housing and insulation.
Besides that, it leaves a residue of microscopic crystals which have probably contaminated the highly-polished metal head drum.
Not to mention gumming up the bushes and bearings.
With your next camera, rather use a head-cleaner DV-tape.
Sony dcr-hc62 won't record
Memory stick could be fubar. I have a bad sd card that I can record to and will work. Then a few days later the data is corrupted, and I have to reinstall it / same pattern. Try another stick to verify that it is the stick and not the camera electronics.
