FixYa.com
KDS Radius RAD-7 17 in. Flat Panel LCD Monitor
All Products > KDS > Monitors
Problems with KDS Radius RAD-7 17 in. Flat Panel LCD Monitor?
Troubleshooting and Support
Solved Problems for KDS Radius RAD-7 17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
KDS Moniter
When I ty to power up all i get is a flashing light and no sceen. the moniter is as follows (model 900p) (product K917s)...
2 Solutions
distorted picture
the screen appears to be vibrating. looks like there is interferance of somekind. tried reseting it but see no...
1 Solution
Dont know how to turn on
where is the power cord located on the monitor? I have Microsoft Windows XP Professional Version 2002
2 Solutions
monitor stays black
I have KDS K717 monitor model no 700P when I turn on the screen just stays black eventhough the power indicator light...
1 Solution
cant turn on
where is the power cord located?
1 Solution
won't come out of sleep mode
the monitor went into sleep mode and never woke up. is there some way to reset the monitor so its not waiting for the...
1 Solution
KDS Radius Rad-5
My mother's monitor will not come on but the green light is on - is the monitor shot or what can she try - I am in...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for KDS Radius RAD-7 17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
KDS 700P black screen
my Kds 700p worked fine then out of no where i went to turn the computer on, the monitor wouldn't do anything,Ive had it...
Post a Solution
Monitor displaying yellow tint
From last few days my monitor display suddenly change in yellow tint. I opened photoshop - turned around - and then my...
Post a Solution
KDS 17
Screen stays black. When power switch is switched off and then on, it lights up faintly for a spli second and then goes...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio350:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.26 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Regulatory ApprovalBSMI · UL · cUL · FCC Class B · CB · TUV-GS · DOC-B · Energy star
Synchronization Range - Horizontal31 - 80 kHz
Max. Viewing Angle - Horizontal140
Max. Viewing Angle - Vertical125
Synchronization Range - Vertical60 - 75 Hz
Dimensions
Depth6.9 in.
Height16.47 in.
Width16.27 in.
Weight13.23 lb.
Warranty
Warranty3 Years
KDS Contact Information
Main support number800-283-1311
Support FAX714-379-5592
Email supportkds_customer_service@kdsusa.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
