20 Most Recent JVC GR-D34E Mini DV Digital Camcorder Questions & Answers
May I know the interface that you're using to connect the Camcorder to the Computer? (Eg: i.LINK, A/V etc)
JVC GR-D34E Mini... | Answered on May 29, 2012
You can download the manual from the manufacturer's web site at
http://resources.jvc.com/Resources/00/00/95/LYT1198-001A.pdf
JVC GR-D34E Mini... | Answered on Jan 16, 2011
I'd like to share my experience with u.
I have an outdated SONY HC-32 mini DV .At first,I had difficulties connecting my cam to my PC.After lots of fuss&buzz it turned out to be the faulty FireWire port at the docking station.Doesn't cost much to fix,but genuine parts (that darn port) was not available.it is then necessary to do some modifications to use compatible parts instead.
No,no,no.problem not completely solved,not yet.
I then could get connections.But it was totally unstable&unreliable.After another lots of fuss&buzz,this time it was the faulty FireWire card that I installed.Replacing with the new one (same cheapo card,but different brand) the problem is now permanently gone.
Hope this helps.
JVC GR-D34E Mini... | Answered on Jul 24, 2010
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
JVC GR Video... | Answered on Nov 27, 2016
Sounds as if the battery needs replacing - have you tried with a spare battery ?
JVC GR Video... | Answered on Oct 08, 2016
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
JVC GR Video... | Answered on Sep 12, 2016
Do you have the sd card that holds the pictures?
Put in computer.
Computer will give you option how to open and save photos.
You do not have to use makers software disc, any photo reader can store your pictures on computer.
JVC GR Video... | Answered on Nov 28, 2015
then don't push pause try record instead .
JVC GR Video... | Answered on Nov 21, 2015
once deleted there is no recovery SORRY
JVC GR Video... | Answered on Jun 01, 2015
JVC GR-D34E Mini DV Digital Camcorder Logo
14 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
computer doesnt recoginze jvc minidv
  • Video Cameras
