20 Most Recent JVC GR-SXM250 Camcorder Questions & Answers
Hi, you see when a Camera's & the like, is/are left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, not to mention, any other sort of corrosion, or perhaps flat cells in a unit, inductors etc. So as said, this makes a unit more or less unrepairable. It still maybe worth taking it to a JVC authorized repairer, and asking for a "Quote" for repair, this way you can make an informed decision, as to repair or replace.
JVC GR-SXM250... | Answered on Mar 29, 2010
This is analog machine, you can not connect directly via digital connection. You need a capture device(composite to USB) available in the market. In case of Desktop Computer a PCI TV TUNER card that has video input can be used to capture videos from you tape. But, video quality in this set up is not as good as videos from digital sources like digital camcorder. Good luck
JVC GR-SXM250... | Answered on Mar 23, 2010
Change CCD. If you are technically inclined you can do it, but take a lot of care not to damage flexible wires. Otherwise have it service by the company. Good luck
JVC GR-SXM250... | Answered on Mar 02, 2010
Dear, You need to get ccd unit changed by a qualified service personnel. This symptom is common in all make cameras using a sony ccd unit.
JVC GR-SXM250... | Answered on Dec 28, 2007
E02 indicates that the mode switch did not rotate into the next position after 6 seconds during unloading attempt. This problem can occur for several different reasons, but almost always requires mechanism repair and retiming, a real pro job. Good luck, magic seadog
JVC GR-SXM250... | Answered on Aug 12, 2007
It looks like your Camcorder will need professional service. This model is famous for blown fuses, however these are surface mounted components about the size of a pin head. Not a user servicable situation. Good luck, magic seadog
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... | Answered on Nov 13, 2017
not sure on this one but it might be the heads in your vid cam may need cleaning.
or the tapes are not running straight on the heads or the rollers in side.
if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp.
try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture.
this could also be a head misalignment fault if it is you will have to take it to some one to have a look at.
if any of the above does not work then you will have to take to some one to look at it.
JVC GR Video... | Answered on Nov 27, 2016
Sounds as if the battery needs replacing - have you tried with a spare battery ?
JVC GR Video... | Answered on Oct 08, 2016
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
JVC GR Video... | Answered on Sep 12, 2016
Do you have the sd card that holds the pictures?
Put in computer.
Computer will give you option how to open and save photos.
You do not have to use makers software disc, any photo reader can store your pictures on computer.
JVC GR Video... | Answered on Nov 28, 2015
JVC GR-SXM250 Camcorder Logo
Popular Tags
12 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
lens cap warning
  • Video Cameras
