20 Most Recent
JVC Cybercam GR-D90 Mini DV Digital Camcorder Questions & Answers
My camera is saying condensation operation
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Showing condensation
That's normal to protect the tape and camera.
You most likely have taken the camera from a warm place to a very cold place quickly or viceversa.
Wait until the camera acclimatises.
How do you upload the Cassette Video into the
This camera has both USB and Firewire (DV) connections. The manual seems to say that either can be used to transfer video. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
You don't say what computer you have. Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB.
As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card.A manual for the camera can be downloaded from
this page.The manual gives some details about connecting to a computer. More information may be available from the same site.
How do you get to
Use the provided USB cable that came with your camcorder. You'll need to install the software and drivers from a CD that came with the camcorder into your computer - if you don't have it, go to the JVC website and download the files. Yes it is possible to upload videos.
My videos won't playback
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
Reading please wait condensation paused
You turn the power on open the screen and it
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. Please contact me either by email [email protected] or by phone 503-819-3502.
Condensation, operation paused
you can try gently drying it with a hairdryer not too close or too hot but try to get the moisture out that is causing your problem. this could have been caused by coming in from the cold to a warmer room. this should fix it.
I GOT THE CONDENSATION MESSAGE AND IT WON'T GO
2 solutions:
1. replaced the motor bracket assy that has the dew sensor on it or
2. there are 2 solder joints you can solder together. on the connector that connects the motor bracket assy to the main mda pcb. Pins 1 and 2
Seasoned camcorder technician 13 years experience.
[email protected]
Uploading a video clip to my computer
The issue may be that your camera captures via FIREWIRE for video and USB for stills. It's a common issue. You'll need hook up your camera to a firewire port. If you don't have one due to this PCs age, you can always pick one up for about $20 and with XP pro, installation is practically plug and play.
But I'll tell you this. If you're computer is that old, do yourself a favor and double the memory. Video is a bandwidth hog and if you don't have enough RAM, you'll run into all sorts of dropped frames and synch issues.
It's also probably time to start looking to upgrade that Dell.
JD
Digital Camcorder HQ
Jvc gr-d90 mini dv
Just turn it on and leave it like that for about one hour. It will clear by itself.
GR-D90 will no longer record onto memory card
Hey,
The card error comes most likely becouse the card is not formated properly, there should be a format card option in the menus somewhere.
Also try to restore the camera to default settings it should restore it the way it was.
I'll look into it, Thanks, report back how this goes.
