20 Most Recent Sony Handycam DCR-TRV30 Mini DV Digital Camcorder Questions & Answers
You should be able to use the RCA connections (yellow/red/white) and plug it directly into a VCR to record. You can also get a cheap capture card to record directly to your computer - but you need a decent machine to process it. There are several sources around for the connection to the computer to camcorder do such what you are doing...
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
Sony Handycam... | Answered on Nov 16, 2017
DIY remove Hi8 tape stuck camcorder Check this link as it might help out to remove the cassette.
Sony Handycam... | Answered on Feb 13, 2014
This small back-up battery on my Sony is under the main big power battery, it is like a large screw under the main power pack, I just turn that screw and the little round lid comes off to get to the little silver flat back-up one.
They are readily available from most good camera shops like Jesops for around £12 to £15 each.
Sony Handycam... | Answered on Nov 01, 2012
Follow the instructions on page 17 of the manual.
Sony Handycam... | Answered on Jul 01, 2012
This worked for me: With camera power on, push RESET (located left of the rec button in the main panel).
Sony Handycam... | Answered on Jul 09, 2011
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... | Answered on Sep 24, 2010
usb streaming is not supported by your new windows OS,reason usb driver is not available. for ilink or ieee1394 connection it should be a plug-and-play connection. no setting in the camera enables or disables ilink output and an ilink driver for the camera is not needed to support this connection (not unless you need to update or reinstall your ieee1394 device driver to get it to work). check this solution link: http://www.kb.sony.com/selfservice/microsites/search.docmd=displayKC&docType=kc&externalId=C86798&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=157560925&stateId=1200%20157576924
hope you can get to establish connection.thanks:)
Sony Handycam... | Answered on Aug 26, 2010
I'm afraid, its mechanical problem in your DCR-TRV30 camcorder and visual check is necessary to inspect mechanism function properly to diagnose problem.
Beeping and displaying error sign is an indication that camera got problem for some reason and there are many possible causes for that like capstan motor is not rotating or rotating on fast speed, video head motor is not spinning, any loading gear got broken, above said motors are not getting power etc etc.
Take your camcorder in nearest local camera repair shop to diagnose problem.
Thanks.
Sony Handycam... | Answered on Jun 25, 2010
Just make sure door is shut and clipped and keep trying, it will release after a few goes.
Sony Handycam... | Answered on Jun 21, 2010
Hello!
Sony Handycam... | Answered on Jun 24, 2009
use s video cord or red white yellow cord to connect. camera comes with a grey adapter patch cord that will help do that easily.
Sony Handycam... | Answered on May 09, 2009
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV30
go here and click driver download
there should be a "hidden"hole for it on the camera,it will have A/V-out near it.
usualy its covered by a rubber cover/plug.
Sony Handycam... | Answered on Dec 18, 2008
Please make sure that tape flap should be straight as shown in below image...
If tape flap will stuck or turned like below image, tape wont be pulled out.
let me know if need further help / info.
Good luck.
Sony Handycam... | Answered on Dec 17, 2008
IF YOU TAKE A LOOK AROUND THE FRONT OF YOUR CAMERA THERE ARE SEVERAL SCREWS, ABOUT 4 I THINK,
1) 1 ON BASE
2) 1 ON THE LEFT LOOKING AT FROM THE FRONT
3) AND 2 INSIDE THE FLASH CASE
REMOVE THESE SCREWS AND THEN YOUR FOCUS RING AND SOME OF THE CASE SHOULD COME OFF
INSIDE THE FOCUS RING YOU SHOULD SEE 3 SREWS IF NOT CHECK THE CAMERA TO SEE IF THEY HAVE FALLEN INSIDE,
IF NO JOY YOU CAN REPLACE THE 3 MISSING SCREWS AND PUT IT ALL BACK TOGETHER
SWEET
DAVOS69
HOPE YOU DONT MIND BAD SPELLLLLING.........
Sony Handycam... | Answered on Nov 08, 2007
hi sounds like the screw that holds the ccd is gone but its inside you say it all works good....? put a SMALL!!! drop of "superglue" (3 sec glue) it will hold nice good luck
Sony Handycam... | Answered on Apr 20, 2006
Sony Handycam DCR-TRV30 Mini DV Digital Camcorder Logo
Popular Tags
29 questions posted
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
hot adjust date time
  • Video Cameras
