20 Most Recent Sony Handycam DCR-TRV17 Mini DV Digital Camcorder Questions & Answers
nope i dnt think ,u wuld nt be having proper jig and tools to repair it as , this problem is related to the mechanical section . ... and occurs due to the tension of new tape .. try using old tape .......
Sony Handycam... | Answered on Dec 23, 2013
Need service in mechanism by expert
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... | Answered on Aug 14, 2011
Possible that:
1. The drum- the cylinder head is faulty , it is not spinning. It could be failure of the IC or the hall IC. need to replace.
2. Fault in the dew switch or is faulty.
3. Fault in the loading tray mechanism as it fails to land.
4. fault with the capstan motor or the forward loading mechanism.
Sony Handycam... | Answered on Jan 14, 2011
Hi. Based on the SOny website here are the list of compatible system for this gadget. That is why windows 7 wont recognize your handycam.
Compatible Operating Systems
  • Windows® 98 Second Edition
  • Windows® Millennium Edition
  • Windows® 2000 Professional
  • Windows® XP Home Edition
  • Windows® XP Professional
Please click this link for reference.
Sony Handycam... | Answered on Sep 25, 2010
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sony Handycam... | Answered on Sep 21, 2010
I think pinch roller lock is broken,its not moving cassette.Please check it pinch roller is inside or not
Sony Handycam... | Answered on Aug 12, 2010
Well mostly when the screen goes completly blank I grab my camera charger and give it a good 5 hr charge, that sorts it out mostly.
Sony Handycam... | Answered on Jun 25, 2010
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Sony Handycam... | Answered on May 31, 2010
No the audio heads are all on the video head drum. Try a head cleaning.
Sony Handycam... | Answered on Apr 28, 2010
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Sony Handycam... | Answered on Sep 22, 2009
run movie maker and connect your camera as u always do
Sony Handycam... | Answered on Aug 01, 2009
eject the tape by disconnecting the power adaptor and removing the battery. After waiting a short time and then replacing the battery, the tape would eject.
Sony Handycam... | Answered on Dec 08, 2007
Try Googling (sony)(CCD-TRA425E)(manual) without parens.
Sony Handycam... | Answered on Dec 21, 2017
Fixya can't help anyone who uses nail polish remover to clean a video head.
Sony Handycam... | Answered on Dec 20, 2017
Sony Handycam DCR-TRV17 Mini DV Digital Camcorder Logo
28 questions posted
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
tape compartment open
  • Video Cameras
