20 Most Recent Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Questions & Answers
after extensive searching I can't find a usb driver for windows 7 . Unfortunately the maker no longer supports later than windows 2000 for their driver. You might be able to run vmware and pretend to have an operating system that is an earlier version like windows 2000 or XP and run a driver in it for the pretend operating
system .
https://esupport.sony.com/US/p/model-home.pl?mdl=DCRTRV22&template_id=1®ion_id=1&tab=download#/downloadTab
https://www.vmware.com/au.html
https://www.vmware.com/support/ws5/doc/ws_newguest_setup_simple_steps.html
I do not think this camera has firewire
but it may have a memory stick
maybe you could look at if you can get a memory stick reader that suits its memory stick.
Sony Handycam... | Answered on Feb 23, 2018
probably best load on usb memory stick and transfer
Sony Handycam... | Answered on Feb 03, 2018
The latest software is available from here:
http://esupport.sony.com/perl/support-info.pl?&info_id=64&mdl=DCRTRV22
Sony Handycam... | Answered on May 13, 2015
USB will connect the still photos from the memory stick.
To transfer the tapes you will require a firewire (Sony calls it iLink) cable for connection.
Al
Sony Handycam... | Answered on Oct 15, 2013
Are you trying to delete the manual from your computer or from the web?
If from your computer, bring up the file browser (Windows-E on a Windows machine, for example). Navigate to the folder the manual is in, right-click the file, and select "Delete." This has nothing to do with any web pages. You can do this just as well when you're not connected to the internet at all. This will also delete the entire manual, not just the first page.
If you need me to be more explicit, you'll have to be the same. What version of what operating system are you running on your computer? Have you tried to delete the manual as described? What happens when you do? Does it keep coming back? Have you tried emptying your trashcan or recycle bin?
Sony Handycam... | Answered on Sep 09, 2013
Delete the file the same way you delete any other file on your computer. If you're using a file browser, try right-clicking the file.
Sony Handycam... | Answered on Sep 07, 2013
I HAVE SONY DCR-TRV22E, AND HAVE WINDOWS 7 ON MY LAPTOP (HP G72). WINDOWS DOES NOT RECOGNISE WHEN I TRY TO CONNECT VIA USB. CAN ANYONE HELP ?
I HAVE READ SOME POSTS SUGGESTING USING A FIREWIRE CABLE - NOT SURE MY LAPTOP HAS THIS CONNECTION - COULD ANYONE EXPLAIN..
THANK YOU.
Sony Handycam... | Answered on Jun 27, 2012
I'm sorry that the Camcorder is displaying the error message. Please follow the troubleshooting steps provided below and check the operation:
1. Please insert a different disc and close the disc tray firmly.
2. Perform Reset by following steps:
1. Locate the RESET button behind the LCD panel of the camcorder.
2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
3. After 2-3 seconds has elapsed, release the RESET button.
3. Perform a manual power reset by following the steps:
1. Turn off the camcorder.
2. Disconnect AC power adapter.
3. Remove the battery pack.
4. Move the POWER switch to the CAMERA position for 15 seconds.
5. Move the POWER switch to the OFF position.
6. Reconnect the AC power adapter or reinsert the battery pack.
7. Turn on the camcorder.
If the issue persists after following all the steps service will be required. You can find repair information and initiate service at:
http://eservice.sony.com
Thank you for your time.
Sony Handycam... | Answered on May 29, 2012
Set the power switch to CAMERA. Press OPEN to open the LCD panel. Press FN to display Page1. Press MENU to display the menu. Select the toolbox icon. Select the third item in the menu.
Sony Handycam... | Answered on May 13, 2012
Error code 31:22 indicates a problem in the cameras tape transport system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... | Answered on Aug 23, 2011
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Sony Handycam... | Answered on Aug 07, 2011
You may be able to download the software required to do this from Sony's website.
Sony Handycam... | Answered on Jul 26, 2011
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Sony Handycam... | Answered on Jul 10, 2011
You should be able to connect with a firewire cable and use iMovie which will be on your Mac. No other software is necessary. Also you can use Final Cut if you have that loaded on your Mac.
Sony Handycam... | Answered on Jun 10, 2011
Sony Handycam DCR-TRV22 Mini DV Digital Camcorder Logo
75 questions posted
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
kakima thank
  • Video Cameras
