FixYa.com
NEC 1560V+  15 in. Flat Panel LCD Monitor
All Products > NEC > Monitors
Problems with NEC 1560V+ 15 in. Flat Panel LCD Monitor?
Search inside NEC 1560V+ 15 in. Flat Panel LCD... Knowledgebase
Troubleshooting and Support
Solved Problems for NEC 1560V+  15 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
Crack
Can I replace the crack screen
1 Solution
lcd wont stay on
the unit will turn on and then it will go blank with the power light turing from green to orange if i turn the unit off...
2 Solutions
mounting a NEC MultiSync LCD 1560
How do I mount this monitor on a wall?
1 Solution
'input not supported'
I bought an acer 1916wab 19" widescreen, not sure this question belongs here, but all I get after windows starts is...
1 Solution
Display completely flipped to side
1 Solution
Resolution Problem
Sometimes when i switch on the computer it displays "Frequency out of range, set resolution". What could be...
2 Solutions
Monitor deosnt turn on
I have had my monitor for quite some time now and recently i got a new graphics card and the monitor doesnt turn on it...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size15"
Color Depth24-bit (16.7M colors)
Max. Resolution1024 x 768
Dot Pitch0.297 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Technical Features
Form FactorDesktop
Dimensions
Depth2.3 in.
Height11 in.
Width13.6 In.
Weight6.2 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
