NEC MultiSync LCD1550ME  15" LCD Monitor
Problems with NEC MultiSync LCD1550ME 15" LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for NEC's latest driver updates.
Troubleshooting and Support
Solved Problems for NEC MultiSync LCD1550ME  15" LCD Monitor RSS Feed Post a New Problem
NEC monitor no power, power light blinks
Have checked caps and transistors on power board. Any ideas?
1 Solution
No power to monitor
My pc was on and working fine when the monitor just turned off. I checked the power cable and the plug fuse had blown. I...
2 Solutions
sink problem
when moniter start then with in two hour in one or two times sink one or two seconds only above side
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Sylvania (ProView) CL2072b Circuit board...
I have discovered that the fuse on the circuit board as blown. I've jumperd it with a very tiny piece of wire wrap wire...
1 Solution
3yr old got ahold of monitor
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational...
1 Solution
Unsolved Support Problems
Unsolved Problems for NEC MultiSync LCD1550ME  15" LCD Monitor RSS Feed Post a New Problem
monitor does not stay on
my monitor is a MAG(INNDIVISION) it goes off every two seconds. I can see the ghost of the screen in the backround but...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size15"
Color Depth24-bit (16.7M colors)
Contrast Ratio400:1
Brightness250 cd/m
Max. Resolution1024 x 768
Dot Pitch0.3 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time40 ms
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Dimensions
Depth6.38 in.
Height14.3 in.
Width13.59 in.
Weight8.6 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Experts
Ask Me
tantong Guru
8 solutions
Ask Me
Microwave Guru
2 solutions
Ask Me
Lemmor Wiz
2 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
