20 Most Recent NEC Mitsubishi Diamond Pro 730 (White) 17" CRT Monitor Questions & Answers
It sounds like the problem is with the computer's video adapter settings. It is very likely that the monitor cannot handle the settings. If you boot into safe mode, can you see everything? If so, then the normal mode settings are too high. Safe mode defaults to the lowest possible settings (thats why everything will look really big) Try turning down the resolution (Right click on the desktop, select properties, go to settings tab) to the lowest possible setting, and then slowly try turn them back up again until you can find the maximum setting the monitor can handle.
NEC Mitsubishi... | Answered on Dec 27, 2008
Hi..
AMR (Adaptive Multi Rate) is common audio file format for mobile devices like mobile phones, laptops, portable recorders.. etc.
in fact totem movie player can't play any amr files (files encoded in amr codec) by itself. Totem Player depends on Gstreamer libs, which haves necessary media handling components .
from your post its not clear that whether your totem can't play movie files from the very beginning or just you can not play movies recently.
your totem player may lacks Gstreamer library files or somehow your Gstreamer libs got corrupted recently.
Reinstalling Gstreamer Library file may help you.
you can find latest source version of Gstreamer on this page
(more detailed download of Gstreamer can be found on http://openports.se/multimedia/gstreamer-0.10 )
NEC Computers &... | Answered on Mar 21, 2019
What is your power and energy saver settings at? Tap windows key and start typing power sl and power and sleep settings should be the first choice. If its not obvious from there, scroll down and or click additional power settings. And the time out reason should be listed and be changable from there.
NEC Computers &... | Answered on Mar 15, 2019
what is it hooked up to? If a windows computer you can quickly do this by holding down 3 keys at once. Ctrl + Alt + choose an arrow key. Tip if your doing this on dual display, what ever screen your mouse last clicked on will be changed when you do this. Ctrl + Alt + left arrow or right arrow depending on orientation desired.
connect it to computer and power source and then right click anywhere on desktop. choose display settings. May need to scroll down in your display settings, but windows 10 will automatically detect additional displays from that screen. Then you can choose extend or duplicate and choose primary and resolution.
In windows or the bios? If its Windows then reinstall windows with an english install media.
NEC Computers &... | Answered on Jan 31, 2019
Firstly, check for reset button on your WiFi extender, press and hold for few seconds till all lights off.
Search for WiFi SSID and connect your laptop or mobile, browse for given ip on extender in browser, give it's password and follow the wizard to complete setup.
NEC Computers &... | Answered on Jan 29, 2019
Order the service manual directly from NEC.
NEC Computers &... | Answered on Jan 21, 2019
Dear Chinthaka,
In the case of nec versapro vz-e tablet pc, I cound't find any button for wifi. Only option to enable or disable wifi is using cmos setup at pc boot up time. Please find in cmos setup at pc boot up time.
Good Luck.
NEC Computers &... | Answered on Nov 27, 2018
NEC NP PA550W User Manual Troubleshooting Indicator Messages ..i know yours is a pa500 but this is all i could find on the internet i just thought it might help you find out how to sort your 500.
it gives faults and what could be wrong.
NEC Computers &... | Answered on Sep 25, 2018
Maybe a space between the name is not allowed. If you press the space bar then it's not allowed if nothing happens. Try using an underscore then the name would look like this: FirstName_LastName
NEC Computers &... | Answered on Mar 09, 2018
NEC Mitsubishi Diamond Pro 730 (White) 17" CRT Monitor Logo
1 questions posted
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Diamond NEC
  • Diamond NEC
Most Popular Question
monitor turning itself off
  • Computers & Internet
