NEC LT 17u 17" LCD Monitor
Problems with NEC LT 17u 17" LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for NEC's latest driver updates.
Troubleshooting and Support
Solved Problems for NEC LT 17u 17" LCD Monitor RSS Feed Post a New Problem
Display PIN settings
In an accident the display cabel was damaged and lost. need the 15 pin display connecter setting/diagram to reconnect...
1 Solution
sink problem
when moniter start then with in two hour in one or two times sink one or two seconds only above side
1 Solution
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
Monitor resolution can't be changed
My Monitor is DAEWOO 15". I am working on 800x600 resolution. I want to change to 1024x768 but it can't be changed....
1 Solution
Sylvania (ProView) CL2072b Circuit board...
I have discovered that the fuse on the circuit board as blown. I've jumperd it with a very tiny piece of wire wrap wire...
1 Solution
3yr old got ahold of monitor
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational...
1 Solution
Problem with monitor
My monitor looks like it has a drop shadow...all the type has a lightened verson of the text or graphics just to the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.26 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time20 ms
Technical Features
Form FactorDesktop
Dimensions
Depth8.27 in.
Height15.96 in.
Width14.78 in.
Weight14.55 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Experts
Ask Me
Sahill Master
5 solutions
Ask Me
PCrx4U Master
1 solutions
Ask Me
usalabs Master
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
