20 Most Recent
Maxdata Belinea 10 17 25 17" LCD Monitor Questions & Answers
Hi have some Maxdata Belinea
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.Please leave rating if it helps.
Built in speakers
Ya, you have to connect an Audio Lead from the Monitor to the Computer. The audio lead would had been shipped along with your Monitor.
You have to connect the "One End of your Audio Lead in the Audio Out socket of your PC and the Other End in your Monitor's Audio In socket". Thats it.
Mainboard
We need more information. Please list your problems and all your computer information. We need very specific detailed questions in order to help you properly
4/1/2014 6:14:24 PM •
Maxdata...
Answered
on Apr 01, 2014
Maxdata Desktop performing slowly than other low PCs.
adding more ram is the best way of speeding up a computer
If you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
you might have to many programs running at the same time putting to much strain on the CPU
try uninstalling a few unnecessary programs
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
then defragment your hard drive
this should speed up your computer
hope this helps
6/21/2012 11:42:07 PM •
Maxdata...
Answered
on Jun 21, 2012
