20 Most Recent
Microtek 715C 17 in. Flat Panel LCD Monitor Questions & Answers
Blows fuse power board
fuses are to stop FIRE.when electronics shorts out, the fuse blows.fix'g that takes skill. and to do it efficiently a special tool is used,we use a current probe to find shorts.lacking tools, its 10x harder, isolating parts, 1 by one and a box of spare fuses.take it in the the geek squad, and go broke,orbuy a new monitor. (i have no idea the cost of yours $100 or $3000 ) nor its age or model number.im a retired tech. Ive even repaired, USN HUGE PPI radar monitors. that yes.catch fire and **** out waves of hot stinking tar , out the bottom. SPA-4's.ive worked it all. need help, post better , input.model numbers and age of monitor.
10/2/2013 1:53:52 PM •
Microtek...
Answered
on Oct 02, 2013
Picture went out during thunderstorm.
hi,
is the power indicator light at the front of your TV lights up during power on?if not then you are correct that should be an open fuse on the power board.You have to open the back cover of the monitor.To identify the power board,It is where the power cord is connected there is a fuse on the power board replace it with the same rating fuse are labeled with current rating such as 5A 250 volts.After you had replace the fuse and blows again after you test on do not replace it again check first the diodes and the regulators on the power board they might got shorted during the power surge.here is a picture of a diode and a diode testing
The white ring on the diode represents the cathode the other side is the anode there should no reverse reading during the test.if you read on a reverse bias diode is shorted..replace it the informationof the diodeis printed on the body of it use it as reference of replacement..
Good luck and let me know.
7/6/2011 10:03:53 PM •
Microtek...
Answered
on Jul 06, 2011
The microtek crt moniter is
The electron cannon from inside the tube for the green has failed, the tube and the entire monitor with it is dead - time for a new one.
5/24/2011 9:00:35 PM •
Microtek...
Answered
on May 24, 2011
I purchased my Microtek ScanMaker
First connect your scanner to computer with usb cable.
Then insert disk in rom then install driver and software from disk.
It is not matter that first you connect scanner or install driver but if you connect scanner first your computer recognized it then you can install driver from disk.
Let me know if you need further assistance.
Thanks for using FixYa.
1/13/2010 5:28:14 AM •
Microtek...
Answered
on Jan 13, 2010
Desperately need ethernet driver for xp
Download from following link.These are updated drivers.
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L)/RTL8139C(L)+/RTL8139D(L)/RTL8100(L)/RTL8130/RTL8139B(L)
Thanks
2/17/2009 11:00:32 AM •
Microtek...
Answered
on Feb 17, 2009
I have a microtek 17' monitor model is 41f
This can be caused by low Screen Refresh rate. Eg 60Mhz. To increase this go to Display propertes > Setting > Advance > Monitor > Screen Refresh rate
Your graphic driver must be installed correctly to be able to make this change.
Please tell me If this dont fix
Best regard
12/5/2008 2:36:28 PM •
Microtek...
Answered
on Dec 05, 2008
