NEC MultiSync FE700  17" CRT Monitor
Problems with NEC MultiSync FE700 17" CRT Monitor?
Keep your PC up-to-date. Get a Free Scan for NEC's latest driver updates.
Troubleshooting and Support
Solved Problems for NEC MultiSync FE700  17" CRT Monitor RSS Feed Post a New Problem
FE700 with double line in the screen
i have 2 lines in the screen , dividing the screen into three parts , plz help me throuth this
1 Solution
nec 700 crt
i have an older monitor its a nec multi sync 700+ when booting up the monitor turns on, with the front led green, while...
1 Solution
MultiSync E700 Monitor Issue
I have an old Sony computer I used with a MultiSync E700 computer that runs on Windows 98. I set it up about three...
1 Solution
CUSL2 & NEC FE700 Monitor problem
I just bought a CUSL2 board and installed it with sb live! value (pci slot #2), aopen pci modem (pci slot #5), and...
2 Solutions
NEC FE700 Monitor Horizontal Problem
Hi All: I've got an NEC FE700 17' flat screen CRT monitor I'm working on.  It runs OK except for a problem...
1 Solution
hi lcd
hi, the screen of my monitor(computer) when i open a some game are shaking
1 Solution
hi light is going dim day by day
i am using microtek monitor..but the light/brightness is going dim day by day...what is the problem what should i do?...
1 Solution
Unsolved Support Problems
Unsolved Problems for NEC MultiSync FE700  17" CRT Monitor RSS Feed Post a New Problem
Problems with colors in CRT monitor (Nec...
I have problems with my CRT monitor. I don't know for what reason but suddenly when I was surfing in the net, the...
Post a Solution
NEC Multisync 5FG slow power up.
NEC 5FG Monitor - I need schematics. DC power takes 10 to 30 seconds to build up enough voltage to power up. When it...
Post a Solution
screen display discoloration and...
Hi ,I have not been using computer for couple of days and this morning i was suprized to see that blue default (xp...
Post a Solution
NEC MultiSync FE700 Plus
I have a NEC MultiSync FE700 Plus and its been in the basement for a while after being used. It is having problems...
Post a Solution
screen space
the screen shows everything to big and I can't see all of the information. I have gone to the controle panel and changed...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size17"
Max. Resolution1280 x 1024
Dot Pitch0.25 mm
Monitor TypeCRT
Viewable Picture Size16 in.
Technical Features
Form FactorDesktop
Synchronization Range - Horizontal31 - 70 kHz
Synchronization Range - Vertical55 - 120 Hz
Dimensions
Depth16.4 in.
Height16.3 in.
Width15.7 in.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
Loading problems.
Top Experts
Ask Me
aceltix Guru
1 solutions
Ask Me
Mergatroi Wiz
9 solutions
Ask Me
ntg1976 Guru
2 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
