NEC MultiSync FE991SB 19 in.CRT Conventional Monitor
Problems with NEC MultiSync FE991SB 19 in.CRT Conventional...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
NEC MultiSync FE991SB 19 in.CRT...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for NEC MultiSync FE991SB 19 in.CRT Conventional Monitor RSS Feed
View More Results for NEC MultiSync FE991SB 19 in.CRT Conventional Monitor
Questions and Unsolved Support Problems
Unsolved Problems for NEC MultiSync FE991SB 19 in.CRT Conventional Monitor RSS Feed
Answer
Hi, i am using a HCL leaptop and some days back i noticed a group of black lines at the right side... (More)
Answer
NEC 19'' AS95F CRT monitor. After a ''zap'' noise inside the case the picture went to max... (More)
Answer
My FE991SB monitor put me in trouble when i it few hour its top portion of screen is showing a... (More)
Answer
It was never like this. There must be a way to brighten the screen. Have I oushed the wrong button ?
Answer
Was typing a document in microsoft word 2003, when power save feature activated and turned off the... (More)
Answer
my TV is a normal TV about 5 years old it frequently flickers on Chanel 1 and Chanel 3. can this be... (More)
Answer
i have a nec pc and water fell on it i forgot 2 dry it and plug it 2 light and now the screen is not... (More)
Find a Manual
NEC MultiSync FE991SB 19 in.CRT Conventional Monitor Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
How to remove the case on LCD monitors
This tip will explain how to open the case on most LCD monitors. Most monitors will eventually have a problem with the power supply and need... written by buddymc
USE YOUR LCD TV AS A COMPUTER MONITOR BY WAY OF HDMI.
To use your LCD TV as a monitor. look for a HDMI output on the computer and the TV. If you dont have a HDMI output on the computer, you will need to... written by tbrat44
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection. To start unplug monitor from power and from computer and test computer with different monitor to find out if... written by ginko
Hannspree, I-inc, Hannsg
Don't buy and products from this company they get cheap parts from companies going out of business. They are built to break down as soon as the... written by worthy42
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
Determine if you are having problems with your monitor or video card in...
Many people have problems determining if their monitor is bad or their video card is bad. One good way to test this is by swapping out your monitor... written by BobbyR1234
if there is discoloration then follow this
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ... so what you have to do is... written by dileep007
LCD and CRT monitors: The fist things you should check
When having problems with any monitor the following are the first things you should check when troubleshooting: 1. Check to make sure the power source... written by BobbyR1234
WikiManual
(Post a New Chapter)
How to Fix a Scratch on an LCD Screen
Use Vaseline petroleum jelly to fill a scratch on an LCD screen. This works because the optical density more closely matches the LCD face than air.... by wikihow
How to Fix a Stuck Pixel on an LCD Monitor
If your LCD screen has a stuck or dead pixel (a point on the screen that is always lit or always dark), it is usually due to a transistor malfunction... by wikihow
How to Improve Image Quality on an LCD Monitor
One method to improve the display on an LCD monitor is to use a DVI connector on a DVI capable video card. This is due to the fact that LCD monitors... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for MultiSync FE991SB 19 in.CRT Conventional Monitor
Nationwide | 5138743306 | Website
We fix and repair laptop motherboard no video, no pow... Read More
Featured Listing
Nationwide | (952)890-7770 | Website
Zkarlo.com provides discount and used laptop parts for... Read More
Featured Listing
Nationwide | 877-934-6198 | Website
Send your laptop to us and we will diagnose the pro... Read More
Featured Listing
Nationwide | (877)729-0812 | Website
We connect to your computer over the Internet to qui... Read More
Featured Listing
Nationwide | 8005882188
Featured Listing
Nationwide | 8664878724
Featured Listing
Nationwide | 8004130133 | Website
We offer computer consulting services, hardware and... Read More
Nationwide | 407-284-1943 | Website
Affordable Laptop and Desktop Repair. We spe... Read More
Nationwide | 254-718-4042 | Website
we Service most consumer electronics. cb's twoway ham... Read More
Nationwide | 601-918-0222
I will connect to your Computer and repair the tro... Read More
Ratings for the NEC MultiSync FE991SB 19 in.CRT Conventional Monitor
Owners Recommend
out of 1
Reliability
Ease of use
Value for Money
Find a Warranty
Specifications for NEC MultiSync FE991SB 19 in.CRT Conventional Monitor
Key Features
Size
19"
Color Depth
Unlimited
Brightness
100 cd/m
Max. Resolution
1792 x 1344
Dot Pitch
0.25 mm
Monitor Type
CRT
Viewable Picture Size
18 in.
Technical Features
Form Factor
Desktop
Regulatory Approval
CE · UL · cUL · FCC Class B · CSA · TUV-GS · TCO-95 · Energy star · MPR-II
Synchronization Range - Horizontal
30 - 96 kHz
Resolutions supported
1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 870 · 1792 x 1344
Synchronization Range - Vertical
50 - 160 Hz
Dimensions
Depth
17.65 in.
Height
17.45 in.
Width
17.41 in.
Weight
48.73 lb.
Warranty
Warranty
3 Years
Supported Models
Black, White
NEC Contact Information
Main support number1-800-338-9549
Describe your problem:
Top Monitors Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
