20 Most Recent Philips DesXcape 150DM (Silver) 15" LCD Monitor Questions & Answers
Will this work on vista os
Hi
Thank you for your query
Yes thsi monitor will work with vista and Windows 7
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - [email protected]
2/24/2010 5:23:26 PM • Philips DesXcape... • Answered on Feb 24, 2010
How to disable theft mode on monitor philips? 276E 4K
The theft deterrence option is available from the SmartControl software that runs on a Windows PC connected to the 276E monitor. See https://www.usa.philips.com/c-p/276E8VJSB_27/4k-ultra-hd-lcd-monitor/support . Scroll down to the Software & drivers section. Then unzip the file to install it. Inside the software, the theft deterrence item is under the Options section of the menu. Since a PIN is needed to enable or disable the "feature". It seems unlikely to be enabled accidentally. Did someone else use the monitor for a while? Are you using a different computer with the Philips 276E? I hope this helps. Cindy Wells
11/14/2023 12:35:19 AM • Philips... • Answered on Nov 14, 2023
Philips Norelco QC5580 Hair Clipper power button repair?
Try these troubleshooting steps If they fail, contact customer support for the product. https://www.usa.philips.com/c-p/QC5580_40/norelco-headgroom-diy-cordless-hair-clipper/support
10/22/2023 3:30:58 AM • Philips... • Answered on Oct 22, 2023
Image flashes for one second on screen then goes away
There could be a few different issues that could cause the behavior you're describing. Here are a few possibilities:
HDMI connection issue: Make sure the HDMI cable is properly connected to both the TV and the laptop. If you're using a HDMI splitter or HDMI switch, make sure those are also properly connected.
HDMI port issue: If you've tried multiple HDMI cables and still have the issue, there could be an issue with the HDMI port on the TV or laptop. You could try a different HDMI port on the TV or laptop, or use a different device to see if the issue persists.
Display settings: Make sure the display settings on the laptop are set to display on the external monitor (the TV in this case). If the laptop is set to display on the built-in monitor, it may cause the display to flash on and off.
Hardware issue: If none of the above solutions help, there could be a hardware issue with the TV or laptop. It's possible that the display controller or other hardware component is faulty and causing the display to flash on and off. In this case, it may be necessary to have the device repaired or replaced.
I hope this helps! If you have any further questions, please don't hesitate to ask.
12/30/2022 2:00:34 AM • Philips... • Answered on Dec 30, 2022
Codice autoradio PHILIPS BMW BUSINESS RDS
ENGLISH ONLY! PHILIPS BMW BUSINESS RDS car radio code Hello, could any of you help me? I'm looking for the ignition code for a bmw business rds radio, 65.12-8 379 230 , chassis PH78500Y1474022 https://translate.google.ca/?sl=en&tl=es&op=translate aqu? est? la respuesta https://www.fixya.com/support/r29874205-need_vehicle_radio_code ..
11/25/2022 9:36:53 PM • Philips... • Answered on Nov 25, 2022
3answers
I CANNOT PLAY REGION A DVDS ON MY 3D BLU/RAY
No disc in tray Press Home Scroll to settings input code: 13893108520 The settings will pop up and you will see that the DVD region is now set to 0 (meaning region free). I have checked the hack on a BDP8000 (region 2)and it sets the region to 0 (the 7th. digit from the left) alright, but it does not make the player region free as a message from the disc (MGM) comes and tell that the disc is not supposed to be played in this region. The region on the player can be changed to the region by changing the "x" in 138931x8520 to the actual region you want to play.Try this out. The hack codec for blue ray are not yet published so it is not possible to make Blue Rays totally region free as of now.
6/15/2022 12:51:36 PM • Philips... • Answered on Jun 15, 2022
Philips drivers is are not to w7!
HI, I would like to help you, however, i would need more specific details about your problem. Ex. Make & Model etc.
6/15/2022 12:43:18 PM • Philips... • Answered on Jun 15, 2022
Philips streamium bios battery?
NO model toldwell in a shop lacking the $100 service manual what do they do?amazing fact they look inside for any coin cell at alljust look, firstdismantle it look/some have sockets and others are soldered down or , there is no such thing.why not stated what works and does not and ask fordiagnostics help. steps.yes batteries fail, all there not changed out yet?if only remote dead it too has batteriesis UNIT DEAD is screen dead, or stuckis wifi only failing.is it struck in stand by mode?page 33 do the RESET YET?lost AC powerlost AC power pack or using the wrong pACK>water dripped in to the unitlclicker dead.no evidence told so answers will be impossible.Philips NP2500/37 WiFi Internet Radio Network Music Player with Rhapsody my wide guess on real name.did you read trouble page in your lost manual.?but only covers wifi. https://www.download.p4c.philips.com/files/n/np2500_37/np2500_37_dfu_eng.pdf
5/25/2022 1:11:17 PM • Philips... • Answered on May 25, 2022
2answers
My philips 191EL LED monitor
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
5/8/2022 10:20:59 AM • Philips... • Answered on May 08, 2022
The press 8 seconds or more does not work with my Philips 227E monitor. Can someone help? Thanks
now a photo review on just buttons (physical) on MON 227E open the window (physical) in room to get some sun light. or use a TORCH (usa flashlight ) and look at all 6 sides of the monolith, main display panel go slow and just look first, as the manuals do stink at makers site (new ones) 2015-undefined-undefined-0.jpg next see year and real models, only manuals matched work learn to tell model, and or learn to google them by exact model or go to philips.com and get it for free. year-undefined-undefined-4.jpg 2012 models too, 10 years ago and are not the same. one some the model is full and on the bottom stand label. older 2012 ,227e4LHab/00(Germany) that is the best I can do , this side of huge pond we have none here,.
3/25/2022 4:25:29 PM • Philips... • Answered on Mar 25, 2022
Will dpfmate.exe for philips photo keychain work on chromebook
NO, WHY WOULD IT>? BUT DO ASK THE MAKER THIS. just learn to backup photos. from the old PC , is the old PC dead>? not told nor its model number or makers name. Udpfmate used software back with old Win98, then new computer to Win XP, downloaded update for 2.5 to work with XP. https://compuland.co/dpfmate-photo-transfer-software/ the maker even died back on 2010 ,11 years ago on this software. seen here https://www.vistax64.com/threads/dpfmate-exe-has-stopped-working.276466/ google finds that and more, it is hard hard subject and odd that old then, not at all common. warning if you download an use Dpfmate from googled sites all those are infected. vast. tread lightly or doom happens. no CHROME OS mostly does not run windows apps. that topic is here. https://www.xda-developers.com/windows-apps-chrome-os/ why not just backup the photos first.????? to a uSB Memory thumb drive.
12/22/2021 12:16:33 PM • Philips... • Answered on Dec 22, 2021
2answers
Booting up Philips 700wac
https://www.youtube.com/watch?v=uJcqHY7YbmA
4/5/2020 4:10:47 PM • Philips... • Answered on Apr 05, 2020
Can`t install netflix app on my philips tv
Even though some TV's are smart TV's and have access to the app store, Netflix app is not available for some models. The best alternative is to get an android TV box.
11/27/2019 6:06:41 AM • Philips... • Answered on Nov 27, 2019
My monitor is Philips BDM4065UC. I think that the back light is not working. Please tell me what part should I change to make it work again.
if power light is on.......if it have suppurate light system ( inverter ) which is locate inside monitor.....if it is inbuilt in screen then it require change its display.......there are many ways for check display open two monitors which are same connect this display with a working one it confirms you your display is OK or not...
5/28/2019 6:51:56 AM • Philips... • Answered on May 28, 2019
Philips monitor 272B8QJEB flashes different colors(black, white, RGB)
clarify your monitor is LCD or doom old one...then it have display problem...it can not reappear...Chang display
5/22/2019 6:46:53 AM • Philips... • Answered on May 22, 2019
Looking for a prehistoric Philips part. Old Philips Computer Model P3103: I require a replacement P3103 motherboard, Philips part no. 5107 200 27001.
Sorry I can't be much help but just wanted to mention Phillips used to have a really good parts service that would share expertise with customers. I don't know what they are like now but I expect if they are in a good mood they could tell you the date the motherboard was produced and which models it was fitted to and any other manufacturers it was supplied to. Such information would allow you to spread your net somewhat wider. Perhaps it might be possible to have your original motherboard repaired, something that was fairly routine in the early days of personal computers...
2/15/2019 12:19:42 PM • Philips... • Answered on Feb 15, 2019
Philips DesXcape 150DM (Silver) 15" LCD Monitor Logo
3 questions posted
Popular Products
Top Philips Computers & Internet Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Computers & Internet
Most Popular Question
will work vista os
  • Computers & Internet
