FixYa.com
NEC AccuSync 900  19 in.CRT Conventional Monitor
All Products > NEC > Monitors
Problems with NEC AccuSync 900 19 in.CRT Conventional Monitor?
Search inside NEC AccuSync 900 19 in.CRT Conventional... Knowledgebase
Troubleshooting and Support
Solved Problems for NEC AccuSync 900  19 in.CRT Conventional Monitor RSS Feed Post a New Problem
NEC ACCUSYNC 900
My colors on my monitor are perfect for a while when I first boot, then it begins to flicker and develops a pink tint....
1 Solution
Redless screen
the color red is totally missing from my monitor.at times the red returns for a short while then disappears.also there...
2 Solutions
I have heard about putting a monitor in...
I have heard about putting a monitor in "sleep mode" to save electricity. What is that, and how do I do it?
1 Solution
How to Adjust the Number of Colors...
How to Adjust the Number of Colors Displayed on a Monitor?
1 Solution
how to fix your speakers
how do you fix the speakers built into the moniter?
1 Solution
Connecting MAC monitor
I have MAC monitor, 17 inch flat screen with cabinet made from clear plastic. One of the late MAC models. Unfortunately...
1 Solution
How to remove internal capacitor on a...
Does anyone knows and could share their tips on removing and replacing an internal capacitor on a flyback? what are a...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC AccuSync 900  19 in.CRT Conventional Monitor RSS Feed Post a New Problem
power options for monitor
hi, the power options for my monitor (NEC AccuSync90) keep going back to shut off after 20 min., i've changed the power...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Size19"
Color DepthUnlimited
Max. Resolution1600 x 1200
Dot Pitch.25 mm
Monitor TypeCRT
Viewable Picture Size18 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalCE · UL · cUL · TUV-GS · DHHS · PTB · Energy star · FCC · TUV-ERGO · MPR-II
Synchronization Range - Horizontal30 - 98 kHz
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 1600 x 1200 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 870
Synchronization Range - Vertical50 - 160 Hz
Dimensions
Depth18.5 in.
Height17.9 in.
Width17.6 in.
Weight40.8 lb.
Warranty
Warranty3 Years
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
