FixYa.com
NEC-Mitsubishi Nec Display Solutions MultiSync LCD1770GX  17 in. Flat Panel LCD Monitor
All Products > NEC-Mitsubishi > Monitors
Problems with NEC-Mitsubishi Nec Display Solutions MultiSync LCD1770GX 17 in. Flat Panel LCD...?
Search inside NEC-Mitsubishi Nec Display Solutions... Knowledgebase
Troubleshooting and Support
Solved Problems for NEC-Mitsubishi Nec Display Solutions MultiSync LCD1770GX  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
How to clean Screens of High End Monitors?
1 Solution
My laptop screen is experiencing burn-in...
My laptop screen is experiencing burn-in along the taskbar. Is this normal?
1 Solution
What's the best way to clean a computer...
What's the best way to clean a computer monitor's screen?
1 Solution
The monitor turns off and on repeatedly.
It comes on and shows the picture but then turns off and comes back on and shows the picture and turns off again...
1 Solution
Monitor is working out of scan range
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. ...
1 Solution
faulty screen
the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and...
1 Solution
Blank screen
Screen is blank, power light is blinking green. Disconnecting the video connection makes no difference. A substitute...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC-Mitsubishi Nec Display Solutions MultiSync LCD1770GX  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
Same as I have read
I have a 17" NEC1770GX monitor. When I turn the computer on, the monitor shows a picture for a secon then dies. The...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio500:1
Brightness400 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time8 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal31.5 - 81 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical160
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1152 x 864 · 1152 x 870 · 720 x 400
Synchronization Range - Vertical50 - 76 Hz
Dimensions
Depth7.8 in.
Height14.3 in.
Width14.4 in.
Weight13.4 lb.
Warranty
Warranty3 Years
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
