FixYa.com
NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD  17 in. Flat Panel LCD Monitor
All Products > NEC-Mitsubishi > Monitors
Problems with NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD 17 in. Flat Panel LCD...?
Troubleshooting and Support
Solved Problems for NEC-Mitsubishi Nec Display Solutions DiamondPoint V71LCD  17 in. Flat Panel LCD Monitor RSS Feed Post a New Problem
resolution notifier v71lcd
resolutin notifier message pops up every time i fire up my computer i find it very annoying. my pc : compaq presario ...
1 Solution
DiamondPoint V71LCD Not displaying image
When the Monitor is 1st powered on or turned on the image comes up for about 2-3 seconds then goes blank. after a few...
1 Solution
Screen Whine
There is a constant high pitched whine being given off from the Hansol 920P monitor which has just started recently and...
1 Solution
medion monitor
monitor turns on to green then goes straight to orange when pc is turned on
2 Solutions
internet problem
my internet not working properly .it stops after working for few secconds
1 Solution
samsung syncmaster 910t won't display
I just cleaned my monitor screen. When turning it back on, it woudl not display anything; it eventually gives me the...
2 Solutions
Screen goes white
A recurrent problem that is now happening more frequently. In the middle of working the screen goes totally white. Used...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Aspect Ratio5:4 (Regular)
Size17"
Color Depth24-bit (16.7M colors)
Contrast Ratio450:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch.264 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time16 ms
Viewable Picture Size17 in.
Technical Features
Form FactorDesktop
Synchronization Range - Horizontal31.5 - 81.1 kHz
Max. Viewing Angle - Horizontal160
Max. Viewing Angle - Vertical145
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624 · 1280 x 960 · 1152 x 864 · 1152 x 870 · 720 x 400
Synchronization Range - Vertical55 - 76 Hz
Dimensions
Depth7.1 in.
Height15.3 in.
Width14.8 in.
Weight10.1 lb.
Warranty
Warranty1 Year
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
