Neovo SX-19A  19" LCD Monitor
Problems with Neovo SX-19A 19" LCD Monitor?
Keep your PC up-to-date. Get a Free Scan for Neovo's latest driver updates.
Troubleshooting and Support
Solved Problems for Neovo SX-19A  19" LCD Monitor RSS Feed Post a New Problem
NO PICTURE
I have a flashing green light on the PSU when plugged into the monitor [sx-19a] when i unpluged it the light goes solid,...
1 Solution
RE FPD1960 power issue
Hi I have no problem sending it to you but can you give me a quote? Thanks azucho98 Hi, I'm in the middle of moving so...
1 Solution
reliysis jm777
the problem is that after approx 20 seconds the screen goes blank
Post a Solution
Gateway FPD 1830 LCD Monitor
When power applied, display briefly comes on -- then blanks off. Power light remains on.
1 Solution
Monitor going to sleep
I think we lost our connection.
1 Solution
samsung crt 591s blank problem
this monitor haven't be use for 2 month ago. before that, this monitor working normally. but today, i start up my pc,...
1 Solution
Output to Monitor and Keyboard.
You have replied me that Power Supply is dead. but Mouse is getting the power supply and Monitor is also getting the...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio700:1
Brightness300 cd/m
Max. Resolution1280 x 1024
Dot Pitch.294 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time25 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Regulatory ApprovalBSMI · CE · UL · cUL · VCCI · CB · TCO-95 · ISO 13406-2 (Pixel defect guidelines) · FCC
Digital Video Input StandardDVI-D
Synchronization Range - Horizontal30 - 80 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical170
Synchronization Range - Vertical50 - 75 Hz
Dimensions
Depth6.9 in.
Height16.5 in.
Width17.5 in.
Weight17.4 lb.
Neovo Contact Information
Main support number1-408-321-8210
Email supportservice@neovo-usa.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
ntg1976 Guru
2 solutions
Ask Me
radarman1 Wiz
2 solutions
Ask Me
Jaimie Guru
1 solutions
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
